So someone dropped my baby, my camera lol, and the lens won't go in. AT ALL. The shutter will not close either. When I press the ON button - the screen is blurred - i can hear the shutter trying to open - the sound for the start up goes a few seconds later - it turns off Please help. This camera cost a lot and I really need to have this sorted ASAP.
I have a camsung L830 that had similar problems and and after I would turn it on, it would beep three times and turn off....but I somehow fixed the lens by turning the camera on and then either pushing/pulling on the part the stickes out and hopefully it might activate the mechanism and it'll go in...that's what happened with mine...the shutters still won't close though. But I'm happy I can use my camera now.
It is extremely difficult for some one to repair these cameras themselves unless it's a minor repair. Very small and irreplaceable parts are inside. One of the lens pieces are most likely bent and where are you going to get one? This is a major repair...take it to a shop.
I dropped my digital camera on the floor , while it was on , and now the lense wont go in and the .
When I turn it on , it beeps about five times and tells me to turn it off and on again. HELP !
How do I fix it ?
Yep, the only time I dropped my camera was in soft sand on the beach. It worked fine for a few weeks after that, and while I was in the middle of taking a series of pictures, it made the angry noise and turned off. Now I press the on button, it immediately makes the same noise, screen cannot focus, it makes the startup noise, and turns off. After conversations with HP they told me it's a hardware problem and they could send me a new camera for $230.00. I tried removing the battery/memory card/pressing the reset button to no avail. Guess I'm just out of luck, but I sure won't be buying another camera from HP!
my camera will not hold a charge i bought a new battery a week ago and it still won't hold a charge
i had the same issue. i took out the 5 screws at the bottom. near battery door. and 4 side screws for front of camara enclosure. removed the frontpart. be carefull the shutter button will come out. not a big deal. I found the cable that connects the camera lens to the camera body was popped up. i just reconnected and that was it.
posted by tempestkc on Aug. 27, 2008
I have this problem now. Did not drop the camera...I baby this baby WAY too much for that to happen. I used the camera to do some indoor shots today and it worked just fine. After trying to recharge it, I tried to turn it back on, but the lens wasn't all the way retracted. When I turned it on, it just does the following...
- it turns off
I tried looking for a "popped-up" cable, but there isn't one to be seen. Is there another fix for this?
Please send ideas/suggestions to my tech email ([email protected]), as I chech that FAR more often than this forum.
Many thanks, in advance.
i dropped my camera and the lens is stuck when i turn on my camera
the shutter is stuck close and when i turn it off the lens stays open
how do i fix it ?
Same damn problem and i broke my friends camera and i'm spazzin out cause it wont fix . god damn god damn , O :
