Question about Datacard SR300-Lam Dual-Sided ID Card Printer with Lamination
How do i resove turn jam error message on datacard sr300
How do I should solve error massage : 103 for Datacard Printer
Power off the printer. Cancel the error message on the PC. Power on the printer. If the issue persists, contact your Datacard dealer.
Aug 02, 2017 | Datacard Office Equipment & Supplies
Lower duplex jam error
It means a card is jammed in the top back part of the printer. You may need to open up the back hatch to pull out the card.
May 06, 2013 | Datacard SP75 Plus Card Printer
Datacard 150i transport error
Hi If you Tel me the Serial Number of you Machine I probably will be able to help
Jan 19, 2013 | Datacard Group 150iDesktop Card...
How to resove the error message "system does not minimum requirement to install this driver" while installing window xp 32-bit drivers on 64-bit notebook(thosiba-C640-11N)?
maybe your notebook is not compatible for xp64 bit try to upgrade in win7 x86 that's much better :))
dont worry on your file it will not be deleted unless you delete your partition. the folder name is "windows.old" that is the folder where save your old files from xp
Apr 01, 2012 | Computers & Internet
Dear Sir I am using Datacard of Airtell Model MMX 610 datacard. when I conntect the datacard, we can use the network for 5 minutes, after 5 minutes, connection is disconncting and giving error message...
Dear! Firstly uninstall the driver of your Data card and reinstall it, if it does not fix, kindly contact your service provider for this problem because I think it is due to network problem but firstly try the tip which I have suggested.
Jul 28, 2011 | Computers & Internet
Datacard CP40 Plus printer with an error. Put a new ribbon in it and it does give us a error message: Error: PR-01739 Ribbon Error Please Help!
Sounds like you are using an incompatible ribbon. Please post the configuration for the printer which is on the left side under the cover (white sticker) and your ribbon part number. If you are sure both are correct you may have a defective print ribbon or your printer will need service.
Contact TulsaBiz.net for more info
Jul 22, 2011 | Datacard SP55 Plus Printer
Sir i have Airtel huwei datacard. and a have allrady break the lock of that dacrd but problem has been occured that datacard is giving a error message. how can i solve this Problem. Aryan Patna Boring...
whats the error message you are getting..
the datacard needs to be enabled at the Service Provider end.
If you have cracked the lock even though if the datacard is not enabled at service provider end then you cant get in..
Dec 23, 2010 | Computers & Internet
Card jam in datacard printer
The rollers in the printer that move the card wear out and the rubber degrades over time, You need to have all the roller replaced and the printer should function like new. Contact MIdWestIDSolutions.com for pricing on parts or service.
Feb 19, 2010 | Datacard SP55 Printer
Datacard SR300-Lam Dual-Sided ID Card Printer with Lamination Logo
53 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
jason
Don  Farrell
Don Farrell
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
