Question about Landice Exercise & Fitness
Landice l7 treadmill owners manual
Pulse sensor not working
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I need instructions for a LANDICE L7 LTD PRO SPORTS treadmill
You can get the manual on link below.
http://site.thefitnessoutlet.com/landice/LandicePTManual.pdf
Posted on Jan 27, 2010
maxtreadmill
  • 832 Answers
SOURCE: Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
Posted on Feb 28, 2010
ercupa190
  • 12223 Answers
SOURCE: landice L7 treadmill won't turn on
1)LUBE the deck belt, maybe you have a deck belt worn, by lack maintenance.
2) Lube the rollers bearings, in according with the maintenance schedule.
3) Test the main motor for voltage input, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
5) After fixing RUN the software calibration for diagnose, and troubleshooting.
Posted on May 09, 2012
I have a landice l7 treadmill that is vibrating even when the drive belt is removed, any ideas?
Check the motor for its stability .
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 15, 2016 | Landice Exercise & Fitness
Will not come on. Has power to it. Is there a restart button? a fuse? What?
Hi Hannah.
The manual for this treadmill can be found here:
http://www.landice.com/sites/default/files/Landice_PST5_Manual%2372116_PDF%203-1-15.pdf
What stands out in these instructions is that there is a red, magnetic safety key that must be connected to the panel to run the treadmill (PDF page 4). Also there is a diagnostic mode covered on PDF page 19 that should let you find out if the treadmill thinks it has some other problem.
Hoping this helps
Good Luck
D
Nov 19, 2015 | Landice L7 LTd Pro Sports Trainer...
Loss of speed sensor
Speed sensor ir sensor wiring is bad
Mar 05, 2013 | Landice L7 LTd Pro Sports Trainer...
Overspeed
Your speed sensor is not working properly this part is located under the motor shroud and on top of drive motor it is attached to a bracket with 2 bolts. Unplug the unit and remove motor shroud see if you can adjust it first by loosen the 2 nuts and moving the sensor forward without making contact to the flywheel, then tightened the nuts up. Plug the unit into the outlet, start the unit, if you still have the overspeed then replacement of the sensor is needed. Call Landice Directly they will ask for model and serial number and they will the new sensor.
Jun 28, 2010 | Landice L7 LTd Pro Sports Trainer...
Feb 12, 2010 | Landice L7 LTd Pro Sports Trainer...
Landice L7 motor voltage in wet conditions
What do you think--what changes when something happens???
Sep 19, 2017 | Landice L8 LTD Cardio Trainer Treadmill
I need a manual for a carl lewis treadmill
You can download the Carl Lewis Treadmill manual here
Apr 20, 2009 | Landice L7 LTD Executive Trainer Treadmill
Exercise & Fitness Logo
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Sportsmith LLC
Sportsmith LLC
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
