Question about Jenn-Air JMW8330DAS Stainless Steel Electric Double Oven
Jenn air jmw8330das micro/oven combo
Microwave not working can I replace microwave only
3 Suggested Answers
SOURCE: jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Posted on Apr 26, 2008
  • 492 Answers
SOURCE: Electronic touch panel unresponsive
Unplug and let sit for 5 min. Replug and set clock time first. Then see if the other buttons work. Electronics sometime need to reboot if it freezes like your computer does sometimes.
Posted on Apr 29, 2009
Wall microwave worth fixing?
There's micro switches and fuses worth fixing on microwaves... if its doing nothing its most likely the fuse on control board. maybe even the breaker.
Sep 01, 2012 | Ovens
Electronic touch panel unresponsive. Clock blinks, but no other commands produce any activity. Model#:JMW8330DAS Serial #:13679516JN Jenn-Air oven. About 2 years old.
Apr 29, 2009 | Jenn-Air JMW8330DAS Stainless Steel...
I have a microwave oven that I need to take out.
These are mounted thru the cabinet above. there should be two bolts which you need to remove in the cabinet abobe. remove these while you have help holding the unit. it will not drop but is kind of hinged on the wall (a lip sits on a bracket on the wall) After removing the two bolts tip the unit forward and lift off the bracket on the back wall.Don't forget to unplug it and pull cord thru cabinet as well Good luck...
Jan 19, 2009 | Jenn-Air JMW8330DAS Stainless Steel...
Jenn-air microwave light bulb
This is an older (Mfgr. May, 1987) microwave oven. Functions perfectly, works an looks good to this day, just no light inside. I searched a couple of websites looking for parts for this unit and appliancepartspros.com provided schematics of the product that I own. From those drawings, it was determined that the microwave oven will have to be slid out of the cabinet above the built-in oven in order to change a $2.37, 40W light bulb. Just a handfull of scrws retaining the oven and exhaust baffles and I'll get it out (onmce the New Year's Eve hangover disappears). The engineer who designed a system like this must have been on an Acid Trip. I haven't looked closely at newer microwave ovens, but I'd have to believe changing a crummy light bulb would have to be made easier than this during the preliminary engineering phase of design.
Dec 31, 2008 | Ovens
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
big job belive it or not the oven will need to be pulled to change it please post your email and i will send you the manual
Jan 24, 2008 | Ovens
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jan 08, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn air combo wall oven/microwave
Jan 01, 2008 | Jenn-Air JJW8230D Electric Double Oven
Hi your microwave is a total separate unit. first check to see it it is plugged into your oven. If it is then to check the fuse. You will have to remove the cover first unplug the microwave remove the screws from the back and side ...pull the cover to the back remove cover. there is a small board on the right side toward the back with a dark gray cartridge fuse. that is you main fuse. you can check it with an ohm meter to make sure it is blown... let me know what you find out?
Aug 25, 2007 | Jenn-Air JMW8330DAS Stainless Steel...
Jenn-Air JMW8330DAS Stainless Steel Electric Double Oven Logo
21 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
