Question about Marc Refrigeration Marc Self Contained Double Duty MeatDeli Case 96inL
MARC OD SERIES open case refridgerator
Can u take apart a MARC OD SERIES OPEN CASE refridgerator to be able to fit through a smaller doorway than the unit??
    Guru:
  • 1,524 Answers
Nope
Posted on Apr 23, 2009
Take case apart
A) Jaws of Life
B) Acetylene Torch
C) M1A2 Abrams
http://en.wikipedia.org/wiki/M1_Abrams
JUST KIDDING!
(But don't tell me you weren't tempted, lol!)
The Acer Aspire AM5201 designation refers to;
A) Manufacturer name - Acer
B) Model Series name - Aspire
C) Model Series - AM5210
The e5621 designation is the Model Number
So, if I refer to an Acer Aspire AM5201, and it is of a different model number; I am still referring to the Model Series, of which your Acer is part of.
http://www.newegg.com/Product/Product.aspx?Item=N82E16883103158
There are four smaller views shown under the large main view.
Click on the three dots after them ( . . . )
This shows you multiple views of the computer.
Click on the ones that show the computer case open.
This shows you that looking at the Front of the computer, the LEFT Side Panel removes.
Believe that the Black lever, that sticks out of the Back of the computer, on the left Side Panel; is to release the Side Panel.
Appears to be you slide it to the Outside, or Down; and this releases the Side Panel so you can swing it out, and off.
Regards,
joecoolvette
(IF, you DO NOT know about Anti-Static Procedures; post back in a Comment!
Do NOT Static shock out the hardware components, inside your computer! )
Mar 31, 2013 | Acer Computers & Internet
How do you open Jabra Cruiser to replace battery
Remove 4 rubber plugs underneath and remove screws.No need to remove sticker.Carefully pry apart the case using small screwdriver then detach speaker connector and set top aside.Remove three smaller screws then carefully pull apart the two boards at the connector. The battery pack is glued to the board and the three wires can be unsoldered. google ahb723938. Good like finding one.
Jul 21, 2012 | Cell Phones
CDC-735
Part Number VQ776900. I got it online for 99 cents but other places can be up to 7-8.00 dollars. I removed 5 screws on the sides and rear of the case. Took case off. Press the open button and help the drawer open with your hand while the motor tries to. Then remove old belt with pliers or paper clip, etc.
I did not take anything apart on the inside to replace the belt. Push the belt into the player over the larger wheel and then I pulled the belt with a paper clip over the smaller drive wheel.
Mar 17, 2012 | Yamaha CDC-755 5-Disc CD Changer
How I can open the case of sony remote controle model RM-GA010
On most remotes there are a series of locking tabs on the sides that can be separated using a pair of flat headed screwdrivers. Press in the tabs using the flattest screwdrivers you can find and push the case apart. You will need to do this down the entire edge of the remote. Sony used a special tool to open these so some damage will occur.
May 04, 2011 | Televison & Video
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Can't get the cabinet back on the base of a sears series 70 washe
What I do is open the lid. I grab the case and look down inside making sure I get the case under the base and on the tabs. Then I tip the case back and make sure I don't pinch the water level fill switch tubing. The back of the washer has plastic spacers on it that allow for a snug fit to the cabinet. The sides fit neatly into those clips with a bit of patience. If you have the front of the base on then the rest is a piece of cake. Snap down the S-clips and reconnect the lidswitch.
Jan 12, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Button worn and stuck
There are a series of molded plastic "hooks" on the top & bottom case running along the handle seam. Once you get the 6 bottom screws out, carefully (!) work a large flat-blade screwdriver between the case halves as it opens, working toward the handle. With careful application of pressure, the handle seam will pop apart. These hooks were only in the very first from production Carousel 4xxx & 5xxx and the Ektagraphic III series. Now you know why they were removed - - it's a pain to get the projector open !!!
Dec 09, 2008 | Kodak Carousel 4600 Slide Projector
Batteries contacts
I have damaged battery contacts and ITT no longer handles repairs.
They told me to contact
AE Optics
817-546-0993
Dana Prather
Jan 16, 2008 | ITT Night Mariner 160 Monocular
Marc Refrigeration Marc Self Contained Double Duty MeatDeli Case 96inL Logo
144 people viewed this question
Top Marc Refrigeration Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Marc Refrigeration Refrigerator Expert? Answer questions, earn points and help others
