Question about Panasonic Mc-Ul594 Eco Max - Bagless Upright Cleaner
My Panasonic hover does not suck - Panasonic Mc-Ul594 Eco Max - Bagless Upright Cleaner
My dc07i has power to hose but isn't picking up when hovering carpets or hard floors the roller is going round but there is no suction
I would guess that the line is plugged between the pick-up where it goes to the dirt tank. Lots of time when something big gets sucked in, it still lets the dirt in the tank. However over time dirt collects around the wedged object and gradually over time plugs the passage way. It may take a little time to pick out the blockage. You may have to somewhat take it apart. to get at it. This happens to my shop vac a lot.
Dec 31, 2014 | Dyson DC07i Bagless Upright Vacuum
Brush won't turn on my Panasonic MC-CB467
There should be a safety reset button. So like if you suck up a rug it will shut the power to the brush roll off, then reset it.
Nov 14, 2012 | Panasonic MC-CG467 Bagged Canister Vacuum
Not sucking the dirt.
Check the hose...they plug up and then everything stops...
Here is a tip that I wrote after having the same issues with my Bissell...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 20, 2010 | Panasonic MC-V9620 Canister Vacuum
My Hoover pet cyclonic is no longer picking up pet hair
You need to replace the belt that drives the beater bar.
Jim
Dec 01, 2009 | Hoover Vacuums
My henry hoover has stopped sucking
screw the pipe off and clean with cold water.
check dust bag or change,
check that nothing is abstructing the suckstion from the head & neck. of your hover,
Oct 29, 2009 | Numatic Henry Bagged Canister Vacuum
Dyson DC07 loss of suction
Hi.
Check brush roller is spinning when vacuuming.
Check short clear hose under machine for rips & blockages.
http://dysonmanuals.llc.nu/
Chris..
Jan 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hover steam vacume F5864
Is it running out of the bottom of the tank, or at the bottom of the machine. If at the bottom, you have a water line off. If at the bottom of the tank, there is a water seal that the tank sits on, may have to replace that.
Oct 03, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Panasonic Mc-Ul594 Eco Max - Bagless Upright Cleaner Logo
Top Panasonic Vacuums Experts
Joseph Hoffmann
Kevin Getz
Kevin Getz
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
