Question about Sony MegaStorage CDP-CX455 400-Disc CD Changer
How to replaced belts on cx455 - Sony MegaStorage CDP-CX455 400-Disc CD Changer
Sony CDP - Cx455 CD player will not play or power off. I can only turn it off by unplugging it. ??
the belts might be off. Take the cover off, and look in the back to see if the belts are loose. If the cd mech can't get back to the home position, then the unit will not turn off
Dec 15, 2016 | Sony Audio Players & Recorders
Repair for Sony CDP-CX455 compact diac player in Marietta, GA area
This site is located in CA USA so we have no access to local businesses in your area, so sorry. Check the phone book or contact Best Buy they repair this stuff I am told.
Nov 09, 2016 | Sony Audio Players & Recorders
Sony CDP-CX455 carosel is getting stuck when trying to go to a numbered disc. I hear belt screeching and the carosel goes back and forth a few disc, but not where it suppose to go.
The belt is stretched/worn and needs to be replaced. In some cases an O--ring can be substituted. Got mine at a hardware store that still carries plumbing supplies.
May 18, 2016 | Sony MegaStorage CDP-CX455 400-Disc CD...
Player won't play discs.. Removed cover, little carousel motor belt wrapped around shaft. Untangled and put back on pulleys but seems loose motor rotates but carousel barely moves
take the belt to your local ace hardware and find an o-ring that is slightly smaller than the belt. Install that and you should be back up and running for less than a dollar.
Apr 04, 2015 | Sony MegaStorage CDP-CX455 400-Disc CD...
The two (2) O Rings are strecshed where can I buy them
take one of the belts to ace hardware and look at the o-rings, there should be something close to the right size
Mar 26, 2014 | Sony MegaStorage CDP-CX455 400-Disc CD...
NEED A SMALL DRIVE BELT FOR SONY CDP-CX455.
if you have the old belt, take it to ace hardware and get an o-ring the same size. it will work just as well.
Feb 12, 2014 | Sony MegaStorage CDP-CX455 400-Disc CD...
How can I acquire an Operating Instruction Manual for my Sony CDP-CX455 400 Disc Mega Storage CD Changer? Is there one available to download online?
You can download the manual from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDPCX455
Aug 06, 2010 | Sony MegaStorage CDP-CX455 400-Disc CD...
Our Sony 400 disc changer won't open. I can hear
If ure an expert, then open up the set, check for alignment balancing for the gears and see if the belting has worn out. Pioneer till today uses belt for ejecting. Belt usually the issue.
Jan 16, 2010 | Sony MegaStorage CDP-CX455 400-Disc CD...
Sony MegaStorage CDP-CX455 400-Disc CD Changer Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
