Canon MF4410 error code E202 - 0002 - Office Equipment & Supplies
5 Suggested Answers
SOURCE: MF4410 ERROR CODE E-202-0002
how can i remove this error E202 0002 on mf 4410
Posted on Nov 05, 2013
  • 29 Answers
SOURCE: canon i-sensys mf4410 error 202-0002
This is a trouble that can be solved only by people that are used to do in maintenance in printers. If you have no experience doing that, I recommend you to look for a solution in your printer's local representant.
- Check the connection of Flat Cable between Main Controller Board (J5) and Contact Sensor.
- Replace the Flat Cable between Main Controller Board (J5) and Contact Sensor.
- Replace the Contact Sensor.
- Replace the Main Controller Board.
Posted on Nov 06, 2013
  • 504 Answers
try following following link
http://www.officeland.ws/Canon%20Diagnostic%20Code%20Chart.pdf
and see what problem u have with your error code
Posted on May 19, 2012
ercupa190
  • 12223 Answers
SOURCE: canon mf4410 error e100-0001
Make this steps and fix it. God bless you
In order to reset a Cannon copier error code you will need to press the additional functions button on the copier. You will now need to press the 2 and 8 keys together at the same time and release them fast. Now you need to press the additional function button again and then press the copier button.
Posted on Nov 13, 2013
I have a canon printer i-sensys MF4410 with error code E301-0001, the problem is that it can not scan and photocopy what can i do to correct this problem?
Code E301-0001
Description
Insufficient light intensity in shading
Remedy
When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies.
(1) Check the connection of Flat Cable between Main Controller Board (J5) and Contact Sensor.
(2) Replace the Flat Cable between Main Controller Board (J5) and Contact Sensor.
(3) Replace the Contact Sensor.
(4) Replace the Main Controller Board.
Feb 18, 2017 | Canon I-Sensys Mf4410 All-In-One Laser...
What dose code 0002 means in canon mf4410
Hi the only error codei i could find for this model MF4410 printer .,is E202-0002 fault description ::: contact sensor HP error,Failure in return remedy. Check connection of flat cable between main control board (J5) and contact sensor . (2) replace flat cable between (J5) and contact sensor (3) replace the contact sensor (4) replace the main controller board.:::: good luck
May 02, 2016 | Canon Office Equipment & Supplies
Error problem
http://forum.testcopy.net/threads/how-to-fix-errors-based-on-error-code-table-of-canon-lbp-3100-3108-3010-3150.693/
Sep 29, 2014 | Canon I-Sensys Mf4410 All-In-One Laser...
How to scan on canon mf4410
Install the MF tool box driver application and sacn.
Aug 14, 2014 | Canon I-Sensys Mf4410 All-In-One Laser...
Canon mf4410 error e100-0001
Nov 13, 2013 | Canon PIXMA MP780 All-In-One InkJet...
What should i do with error e100-0001 on mf4410. i changed fuser film and when i closed the all the panels the machine falshed this error code e100-0001.
Nov 13, 2013 | Canon I-Sensys Mf4410 All-In-One Laser...
I sensys mf4410 canon printer display e202-0002
open the scan and make sure that marked ruler like thing where the scana light rest is tightly fixed. that's it ,the error won't appear anymore
Apr 21, 2013 | Canon I-Sensys Mf4410 All-In-One Laser...
Mf4410 error code e100-0001
Code error e100-0001 canon 4430
Was This Helpful?
Sep 17, 2012 | Canon I-Sensys Mf4410 All-In-One Laser...
May 19, 2012 | Office Equipment & Supplies
1,282 people viewed this question
k24674
jasbo
jasbo
