Question about Roland JUNO-Gi 61-Key Mobile Synthesizer with Digital Recorder
Keyboard juno gi show program error - Roland JUNO-Gi 61-Key Mobile Synthesizer with Digital Recorder
How to program arrpeggiator in Roland Juno D
The information is in the manual. You can download a copy here-
JUNO Owner Manual JUNO Manuals Support Roland
Feb 27, 2015 | Roland Juno-D
Some keys of my Juno Di got Out of tuned :( pls help
Un screw your DI and remove the rubber pads under the keys and gently whip any liquid under it and on the key on it .the liquid is acting as resistance to result in de tune.
Nov 19, 2013 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
HI, I have a Roland Juno GI, (5 months old), have not programmed anything into it or changed any settings. However, when I started it today it was flat by 50 cents. I was sure of this by checking a D or G...
It sounds like it is transposed. Look for the transpose function in your user manual. It shifts the keys by half notes either up or down. I would be surprised that factory reset would not clear the transpose setting. First, realize that these keyboards are controlled by a crystal oscillator and they just don't drift enough to shift even one cent worth.
IF the unit is NOT transposed, then the other problem is LIKELY with the pitch bend wheel. Try the action of the wheel and make sure it responds by moving up and down about 50 cents. If it doesn't go both ways, it is possible the mechanism has slipped or been damaged.
Jul 19, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
Where can i get a screen replacment for the juno g ? and how much is it?
You will have to go to Roland parts to get the item and the price will vary depending on your location. The display is going to be expensive... Here is a site...
http://www.instrumentalparts.com/rojuglcdscju.html
$205 it looks like... I would contact Roland directly first. Use google to find their contact info.
Apr 11, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
The fonts on my digital interface on my keyboard are sometimes upside down
I will note that MANY of the "smart" LCD displays have the ability to turn the displayed information upside down by either a command or a jumper. I did NOT find any parameter you can set in the Juno-Gi to set this in the manual... it is a mystery... Possibly there is a cable to the LCD that is loose. You need to correlate when this happens to other events or actions to narrow down the problem.
Feb 11, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
A gap occur when i change tones on my juno G i.
Yep! When changing VOICE's (we don't call them tones) the generator chips and processing within the synth has to clear out the old voice generation and free up the generators for the new selections. As fast as the processors are, gaps can occur.
Some of the higher end synths are much faster or have so many generators available and processing power that they can do a more orderly transistion.
I am not sure how many generators the JUNO has, but tyoically two are used for every note being keyed. The specs say 128 note polyphony which should be the number of generators... HOWEVER they say these are SHARED with the audio track section. Layering of voices will also divide the number of available generators.
A lot of the arranger keyboards are NOT intended to be played LIVE and as a result transistions of voices are not done on the fly smoothly.
Feb 07, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
Can I update roland Juno G Old version to new?
Here is the link you need but pay absolute attention to the Please note section in each case as the Juno D LE and the original Juno D are different. If you install the wrong update you will have problems with the keyboard working at all.
Jul 17, 2010 | Roland Juno-D
Every sound is modulating as if there's tremolo on
If you have the new Juno here is a link to their update:http://www.rolandus.com/products/productdetails.php?ProductId=429 Also try looking in your manual for the initialisation procedure. This will return your keyboard to the factory settings .
Feb 28, 2010 | Roland Juno-D
Where can I take my roland juno keyboard to be repaired lost soun
juno, lovely instrument, try the synthesizer repair centre in london
Feb 06, 2010 | Roland Juno-D
Roland JUNO-Gi 61-Key Mobile Synthesizer with Digital Recorder Logo
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
