Question about Sony KP-44PX3 44" Rear Projection Television
Sony kp-44px3u rear projection tv spider and cobwebs inside
I need to know how to get inside the tv
  • 19 Answers
SOURCE: cleaning the INSIDE of a rear projection tv - Panasonic PT-51G35
its better to see any experts near you,its risk your tv.
Posted on Oct 30, 2007
ladywinn
  • 5138 Answers
SOURCE: sony kp-51ws520 what bulb does it take
Tube numbers on tubes.Red Green Blue?
Posted on Dec 25, 2008
SOURCE: cleaning cobwebs from philips rear projection tv model 51PW9363/1
I had the exact same problem and the fix is easy to do. Unplug the TV first of all and wheel it out so you can easily get to all of the rear screws.
  1. Remove the screws from the ventilated back panel (the piece of wood with a bunch of holes in it surrounding the AV connection panel.
  2. Remove the wood panel you just unscrewed.
  3. Remove all screws from the upper plastic case on the back.
  4. Remove the back plastic case carefully. This is a little tricky due to two metal pins that it hangs on. Lift it upwards and you should be able to free it from these pins
  5. At this point you should be able to see the entire workings of the TV, and consequently the massive amount of dust that has accumulated.
  6. Carefully take a vacuum and remove all the cobwebs, taking care not to bump the mirror or the lenses.
  7. First, I used some compressed air to clean off the lenses and then used a clean microfiber towel to remove all the dust from the lenses, the mirror, and the screen on the inside. Make sure the part you are wiping the mirror and lenses off with is free from any dust or dirt or you will risk scratching them.
  8. Reverse the dissasembly process to put the case back together.
  9. I went through the convergance settings at this point and found that they were all out of calibration and as such recalibrated them. Use the mulitpoint calibration for best results.
  10. Enjoy a much cleaner brighter TV!
Posted on Mar 25, 2009
johnnydiode
  • 647 Answers
SOURCE: Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Posted on Oct 24, 2009
Testimonial: "Many thanks to johnnydiode and all the others on this site sharing their knowledge and providing a valuable service."
SD Tech
  • 14553 Answers
SOURCE: sony rear projection tv showing double
If you have a CONVERGENCE problem and it will not adjust---the two STK-392-150 Chips this set uses need to both be replaced and the set adjusted with the original remote control.
You can, if you are able to do the repair, buy a pair of chips for less than 14 dollars plus shipping on Ebay.
If you cannot do the repair--shop around your area--most shops are going to charge 300 or more for this kind of repair.
When you consider the cost of the parts--if you can do it or know someone who can--you can save the set and a lot of money--This repair can easily be done right in your home in about 1 hour--I know as I have done hundreds of them---did two today.
The chips (with the back off of the set) should be on two metal heat sinks on the board on the far left---they will be facing the front of the set.
All that is required to get at them is to remove all the plugs on that board and the screws that hold it in and tilt it up so the bottom of the board is in view---you unsolder both chips (about 18 pins each) and remove the 2 screws that hold each to a heat sink.
With 2 new chips you put heat sink compound on the back of each--it is a white grease to move heat quickly from the chip to the metal, and solder both chips in----put the board back down and all the plugs back(I usually mark all of them so I know where they go) and turn the set on and see what you have...
Most of the time this repairs the set--go into the customer menu and adjust the convergence and you are ready for another 5-8 years of life---this is the normal lifespan of these chips.
If you need assistance or have questions let me know--I am here to help people.
If this information helped you, rate this solution as I do this here for free.
SD TECH
Posted on Nov 08, 2009
I was Given a sony tv projection model no kp-44px3u and require a user manual guie can you help
SONY CRT Projection television.
This looks like an 'Asia' model probably used in New Zealand.
You can get a manual by going to;
http://www.sony-asia.com/support/product/kp-44px3u/manual
Then click on the Operating Instructions link.
» Operating Instructions
File Size: 1.43 MB
Part Number: 4-102-591-41(1)
Date: 31 Mar 2004
English
Apr 15, 2011 | Televison & Video
Hi I have a Sony KP-41DS1U projection TV. There is hair or cobweb that 'floats'on the screen. Can I get access to 'blow' or clear it. Many thanks John
You could unscrew the screen frame from the rear cabinet. You only need to get a bit of a gap to gain access. Then use a flexible cleaning wand to clean those spider flowers out of there.
Mar 15, 2010 | Televison & Video
Spider webs in tv
Easiest way to deal with this is unplug set and remove the back cover. The area inside is fairly open---with a swiffer type duster reach in carefully and remove all the spider webs. Go easy along the inside of the inner screen so you do not scratch it or damage it.
Let me know if you have questions.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 08, 2009 | Sony KP-51HW40 51" Rear Projection...
How doI take the cover off to clean the inside of the protective screen? sony KP-53v80
I removed about 6 or so screws took back cover off and used a duster to clean the inside screen it cured my cobweb problem.
Sep 12, 2009 | Sony KP-53V80 53" Rear Projection...
COBWEBS DRIVING ME CRAZY INSIDE MY SONY TV HELP!
Easy way to deal with this is to unplug set and remove back cover-----with one of the Swiffer type dusters(there should be plenty of room inside this set) gently reach up and get all the webs out---also a good idea if you do this with a lens cloth or paper towel with windex clean the three large black lens you will see when you remove the cover---they usually need to be cleaned about once a year(if they are dusty the picture will be darker and not a clear)
If this has been helpful give me a vote here.
Aug 17, 2009 | Sony KP-53V80 53" Rear Projection...
How do I dust inside the screen of a Rear projection TV?
Unplug tv first Usually you can pop the front screen off the set. There may be two hidden catches depending on the model. You may want to use two people for this. Once the screen is off removed the spider web and clean the back mirror with some windex, don't clean the inside of screen with any cleaner. Replace carefully the screen making sure it clicks back correctly
Mar 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Possible spider web inside of reprojection Tv
Yyou can clean screen's internal side by takeing off back cover of tv. Belo is picture how to open back cover.
Sep 24, 2008 | Sony KP-46WT500 46" Rear Projection...
How do i clean my screen
You can clean the screen from the back - take off the access panel. I clean mine once a year whether it needs it or not.
Apr 23, 2008 | Sony KP-53V80 53" Rear Projection...
How do i take the front panel and screen off my sony KP-44PX3U
There is a video on YouTube that shows how to clean the screen of your tv and you have to do it from the rear of the tv YouTube a picture is worth a thousand words hope this helps Merry Christmas
Dec 17, 2017 | Sony KP-44PX3 44" Rear Projection...
Exploded view diagram
1) Remove rear cover. Slide out pressed-board light shield.
2) Remove any cobwebs behind screens-(soft cloth on pole)
3) wipe lens caps with soft cloth
4) re-assemble
Oct 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-44PX3 44" Rear Projection Television Logo
321 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
