Question about ViewSonic PJD6241 3D DLP Projector
Power light lamp standby solid - ViewSonic PJD6241 3D DLP Projector
2 Suggested Answers
  • 144 Answers
SOURCE: PJ552 Viewsonic shutting down solid red power and lamp lights
reset the timer.
Posted on May 08, 2010
I replaced the projector lamp and still no light what am i missing. all i get is a solid red lamp indicator and a orange power indicator.
hi,
Did you reset the lamp hour after replacing the lamp. If not do the following for the same and try again. Also check is the lamp inserted is correct or not. Also check the lamp cover is properly closed or not.
press the "Help" button on the remote control for a minimum of 10 seconds while in standby mode. When the lamp time clock is reset to zero, the LAMP indicator (red light )goes out.
ok
Feb 10, 2011 | NEC VT465 Multimedia Projector
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Only power light will power on for few seconds then flashes.
Does the main lamp light at all? It sounds light a cooling fan failure. If the fan iis not working the the main lamp will not turn on and the power light will flash.
Jan 07, 2009 | Optoma EP755 Multimedia Projector
Thomson DTI6300-16 digital TV recorder frozen, red light on constantly, no resposnse to any commands. I think it needs a factory reset - how do I do this?
Try Resetting the box to its factory setting:
  • Menu > Setup > Help
  • Then press the Green Button (Even though it doesn't show as an option)
  • Then press the Red button for a full reset
Warning: You will lose all data on the Hard Disk!
I did this when mine wouldn't record anything and dumped all my pre-recorded programs.
Worked a treat.
Jul 20, 2008 | Televison & Video
Intermittent lamp turn off
I was told by the repair service to unplug the power cord for about 5min. This resets the internal computer. I think this helps but does not cure the cause. Good luck.
May 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
SONY GRAND WEGA
I have a KDF60XS955. When I power it on, the fan comes on, the standby light flashes green several times, the lamp comes on and the standby light goes to solid green. This lasts for less than 5 seconds then the lamp goes out, followed by ~30 green standby flashes, the lamp coming on with the solid green standby light for about 5 seconds then shuts off the lamp again. I can hear/feel the fan running the enitre time. This cycle continues endlessly. Please help!
May 20, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Thomson dti 6300 freeview box will not come on just shows constant red/orange light flashing all the time, tried leaving power off etc....anyone know?
What to do: if you have a solid amber light If the power light on the box will not change from solid Amber to solid Red then it is possible that a problem has occurred with the current in use software. Before attempting a fix, power the box off and on at the power socket and then wait at least 5 minutes for the solid RED lamp to appear.
If it still remains solid Amber and the box will not come out of standby to ON (Green light) then this can be corrected using the software revert procedure which is done using the box front panel buttons as follows:
1. Remove power to the unit by removing the power cable from the back of the box.
2. Wait 20 seconds and then restore the power cable while pressing the standby button repeatedly on the front panel of the box.
3. Release the standby button immediately when you see a lamp flash on the box's front display, and then immediately press the following front panel arrow buttons in this sequence:
- Menu
- OK
Note: you have to do this quickly and in sequence
4.The Orange light will flash and the STB will then reboot and should return with the previous version of software.
5. The box will now be running with the previous software version but it will automatically update with the latest version within approx 2 hours and you will be notified by message which will appear in the Message area within the Main Menu.
If you're still having problems please call 08444 159 159 and a member of the Technical Team will be happy to help.
Apr 13, 2008 | Televison & Video
Two solid red lights on
This will most probably cost you replacement of the lamp
Mar 04, 2008 | Sharp XR-10X Multimedia Projector
ViewSonic PJD6241 3D DLP Projector Logo
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
