Question about VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
Protocol error 8 - VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
Call for services code : E7-80
Communication trouble
between the MFP control
and the scanner (MFP
control detection)
Communication
establishment error/
framing/ parity/ protocol
error
Follows the
communication protocol
specifications.
Communication error,
timing abnormality of the
communication data and
the communication signal
line
Dec 05, 2013 | Sharp AR-M700N Copier
Unable to load client protocol
b> Internet Protocol, also known as IP, is a communication protocol which heavily uses the TCP/IP standards for packet switch internetworking. IP manages addressing methods for data encapsulation and delivery. IP was developed by the United States Department of Defense and is now widely used by the public. IP Version 4 is the fourth version of Internet Protocol and the first one to be deployed to the public. Updating and installing Internet Protocols are important to the integrity and reliability of your Internet connections.
Click the "Start" button at the bottom of your desktop screen. Click on "All Programs." Select "Run" from the Accessories folder. Type "CMD" in the run dialog box. The command prompt window will appear. Type "Netsh Interface ipv4 install" on the command prompt line. Press "Enter." Restart your computer.
Add or remove a network protocol, service, or client
http://windows.microsoft.com/en-GB/windows7/Add-or-remove-a-network-protocol-service-or-client
Feb 06, 2013 | Microsoft Internet Explorer 8
How i fix Error 105 (net::ERR_NAME_NOT_RESOLVED?
Changing the DNS settings to 8.8.8.8. and 8.8.4.4. on BOTH the modem/router AND on each pc on my network in the Tcp/Ip lan or wan settings (in detail bellow) solved this ERROR 105 issue for me,
To change DNS settings (in Win 7) go to Control Panel / Network and Internet / Network and Sharing Center (may be listed as "View Network Status and Tasks" in control panel)
Next click on your connection (Local area network or Wireless area network)
click on Properties
select Internet Protocol Version 4 (TCP/IP v4)
click on Properties (yes, again, but this is a different window)
click Advanced and select the DNS tab
Select any DNS addresses here and Click remove. Make sure there are non left
Click OK. you should now be back at the "Internet Protocol Version 4 (TCP/IP v4)" window
without altering the IP settings at the top, select "Use The Following DNS Server Addresses"
in the first area write 8 . 8 . 8 . 8 .
in the second write 8 . 8 . 4 . 4 .
next either:
1 select "Validate Settings Upon Exit" and press ok
or
2 press ok and then restart the network connection for changes to take effect
(In other words find your connection in "Network and Sharing Center" and click the
"Connect or Disconnect" option above it to disconnect, then select connect to a network in the
same window, select your network and click connect")
Mar 17, 2011 | Google Chrome
How do I turn off ECM in my Brother MFC 8220?
From the Brother website:
If you are using Voice Over Internet Protocol (VoIP), (a technology that allows you to make telephone calls using a broadband Internet connection instead of a regular (or analog) phone line, review the information listed below. If you are not using VoIP continue to Step 8.
Voice Over Internet Protocol (VoIP) is not a marketed feature of your Brother machine, however there is a compatibility setting available with this machine that may assist with sending and receiving faxes when using VoIP. Adjusting this setting lowers the baud rate (modem speed) and turns ECM (Error Correction Mode) Off. To adjust this setting follow the steps listed below:
  1. Press Menu or Menu/Set => Fax => Miscellaneous => Compatibility.
  2. Select Basic.
  3. Press OK or Menu/Set. (For touchscreen models, skip this step.)
  4. Press Stop/Exit.
Jan 07, 2011 | Brother MFC-8220 Fax
Error 720 - the connection attempt failed because your computer and the remote computer could not agree on PPP control protocol. Gateway Desktop
To resolve this behavior, follow these steps:
  1. Find out which protocols the RAS server is running, and make sure that the RAS service is installed and configured properly (or ask the Network Administrator to do this).
  2. After you find out which protocols the RAS server is running, make sure that your Windows XP-based computer is running one of the same protocols that the RAS server is running:
    1. Click Start, click Control Panel, and then double-click Network Connections.
    2. Under Virtual Private Network, right-click the VPN connection, and then click Properties.
    3. In the VPN Connection Properties dialog box, click the Networking tab, and make sure that you have a protocol that the RAS server is running.
  3. If you do not have a protocol that the RAS server is running, add the needed protocol:
    1. Click Install, click Protocol, and then click Add.
    2. Click the protocol that you need to install, and then click OK.
    3. Click Close in the VPN Connection Properties dialog box.
May 30, 2010 | Acer Aspire T650 PC Desktop
Error 734 ..ppp protocol terminated in .Aircel pocket internet
dear Sir,
I have the mobile handset samsung GM S 3310. I am usuing Aircel Pocket internet in this phone. Surfing net is not a problem from the handset , but unable to connect it to my laptop.
Before dial up, it gives :error 734 ..ppp links protocol terminated. Therefore I Can not connect pc to handset as the dial up connection is not established.
Oct 28, 2009 | HTC S710 Smartphone
I have yahoo id i wand configure to my outlook express i am getting this error There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server:...
There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server: 'pop.mail.yahoo.com', Protocol: POP3, Server Response: '-ERR [SYS/PERM] pop not allowed for user.', Port: 995, Secure(SSL): Yes, Server Error: 0x800CCC90, Error Number: 0x800CCC92
make sure your password is correct because this error description states that your password is incorrect
Jul 08, 2009 | Microsoft Outlook Express
Enable LAT protocol on Shiva Atom?
Since the only thing that changed was the Shiva Atom, I'm guessing that the license error is coming from the terminal server itself rather than the VAX, corrrect? My only suggestion would be to replace the ethernet chip on the new server with the one from the old server. Perhaps the license is tied to that address. It should be a small 8 pin IC in a socket. At the time of these units being built, the Ethernet ID chips were usually installed in sockets.
Hope this helps,
Dan
Apr 30, 2009 | Intel ShivaPort Atom (SATOM16TX) Terminal...
Error 230 en Escaner NCR 7875
You need disable the scale scannig the bar codes for programing
Program mode
304
save and reset
301lbs to kg
302kg to lbs
303enable scale
304disable scale
305 Protocol comunication
306 Protocol comunication
307 Protocol comunication
Oct 08, 2008 | NCR 7875
Chat session not working
Hi again,
There is no problem with your chat software.All you have to do is just have alot of patience once your signed in it can popup anytime..
Apr 28, 2008 | Microsoft Office Outlook 2003 for PC
VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA) Logo
20 people viewed this question
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
