I have big screen tv the model is either kp-5w3500........or kp-5w8500 the ser no is 9c16172 manufac date is Sept 2002 i need help getting front panel off to get the dust out....right now it wont do nothing just the standbye light comes on.
  • 8,617 Answers
The model number is KP51WS500 or KP57WS500. If you look at the lower edged of the front panel on each outside edge you will see two plastic plugs remove those two plugs and you will see the screws that secure the panel
Posted on Apr 26, 2009
Sony kp-57wv700 cannot adjust color or hue
if you have a big sub right against it it needs to be moved away as the magnets can affect the big screen picture.
Mar 30, 2012 | Sony KP-57WS500 57" Rear Projection...
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
Dec 30, 2011 | Sony Televison & Video
DOUBLE IMAGE ON SCREEN. tOP OF PICTURE LOOK LIKE A
That symptoms are due to failure of convergence out ICs in your TV that will be replaced to get correct converge picture on front screen.
There are 2 big black IC mounted on big aluminum heat sink and number would be written on as STKxxx, these 2 ICs will be replaced.
If you want to repair TV by yourself then confirm model number of TV to provide you more info or call local tech to replace said ICs.
Thanks.
Dec 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Is a sony big screen tv model number kp43ht20 a hd
Yes.The best way to hook up this set is using the Component input (R,G and B inputs) with red white for audio
see link to specs
http://www0.shopping.com/xPF-Sony-KP-43HT20
Oct 30, 2009 | Sony KP-43HT20 43" Rear Projection...
Sony 57" projection TV - need replacement screen
The part number for the screen for the KP57WS500 does not match the one for the KDP-57WS550. The inner screen is still available for the KDP using part number 4-095-924-01 for $120.32
Hope this helps,
Dan
Mar 23, 2009 | Sony KP-57WS500 57" Rear Projection...
The tv just randomly turns off by itself
Check to see how many times it blinks when turning off and then look for the codes for Sony tv blinks. this will tell you what's wrong. This set is notorious for Shorted tubes.
Feb 27, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57wv600 big screen
you will need to replace the Green CRT your model uses the sony # 873365201 CRT. The other site I work for just got a shipment of Sony and RCA CRTs(Tubes) in on friday. So you can get one at the following link these are brand new Tubes and they provide free shipping and free on line tech support with instant messageing in case you need help installing it. Heres the link.
http://servicemanuals.vstore.ca/
Jun 22, 2008 | Sony KP-51HW40 51" Rear Projection...
Sansui tmv1916 tv no pic
have a sansui tv with a date of sept 2002 i bought the tv because it was on sale and have since lost the reciepts. anyways , no i need the tv and when powered up there is no picture but the sound comes on fine. i turnd it upside down and beat it and shook it and the pic came on for a min only to turn back off in 5-6 minutes. help. oh and i dont have electrical or circuit knowledge but willing to change a bulb or fuse. as you say that sound is ok and picture also comes some time so please check loose contact in luminance section of chroma ic . weak signal may cause rolling and intermittant picture problem for that checkloose near antena socket thanks
Sep 10, 2007 | Sansui TVM1916 19" TV
TV turns off-on when I try to adjust the volume
check tact switchs ALL on the control panal. several with leaky switchs.good luck wayne
Oct 22, 2006 | Sony KP-53V90 53" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
