Question about iPhone Apps
Can't get bluetooth to connect when trying to sync my ride
Not connect Bluetooth
depending on what device youre trying to connect to your bluetooth. there should be an option on the device that says "connect bluetooth" or "bluetooth speaker". if you click that and follow the guide to sync the bluetooth to the device you should have no problem.
Nov 20, 2016 | Cell Phones
Tip
How do I automatically start Bluetooth?
<p>Bluetooth is a wireless connection method used for two different devices together, like a computer, cell phone, headset or sync. You are required to enter code synchronization when connecting two devices, but most likely you do not want to enter this information each time you want to sync the hardware. Instead, you can automatically start the Bluetooth devices in sync with each other. <br /> <p><br /> <p>1. Turn on the Bluetooth device (such as a headset) and the hardware you want to synchronize with the equipment (such as your computer or mobile phone). <br /> <p><br /> <p>2. Click the "Start" button when using a computer, select "Control Panel" and finally "Hardware and Sound". Select "Bluetooth Devices" and click "Add" and wait for the computer to search for Bluetooth devices. Press "Setup" when using a mobile phone, select "Bluetooth" and activate the configuration. This allows the phone to search for the Bluetooth device. <br /> <p><br /> <p>3. Select the Bluetooth device, once it is detected (both computers and mobile phones) and enter your pair of four-digit code (listed in the user manual of Bluetooth device). <br /> <p><br /> <p>4. Press "OK" on your computer or mobile phone connects to Bluetooth. Now each time the devices are enabled on the phone and the computer automatically detect and connect to Bluetooth devices. <br />
on Jun 26, 2011 | Computers & Internet
Customer help line
Here are the steps:
1. Make the partnership between the phone and the pc with the cable first and let it sync once.
2. Unplug the cable, turn on the bluetooth and make the pc and phone connect through bluetooth and save the device in the device list so it can connect everytime you want to sync without adding the device again.
3. Once they are connected to each other run active sync (with bluetooth still active) and press Menu-Connect via bluetooth. Here's the tricky part, it wont always connect. You have to do this a couple of times until you get a connection. For me its like 4-5 times and i get connected.
Thats it.
May 20, 2014 | Cell Phones
Music player through my bluetooth
Hi Mike Cronk,
I see that you have a Bluetooth Headset and that you are tryingto connect it to your BB.
You mentioned it will not play or you cannot hear Audio From it from your BB?
Did the Bluetooth Headset sync to your BB? you need to make sure that the headset is sync properly on your BB and that the BB is dectecting your Bluetooth Headset. make sure that the BB is also set to be detected by any device for the Bluetooth to detect your BB as well for proper syncing of both devices.
try your Bluetooth headset on another devices as well see if it will sync to a different device just to see if the Bluetooth headset is working fine.
I hope this helps,
michaelvincentc
Dec 25, 2011 | Jabra BT2080 Bluetooth Headset
I bought a madcatz bluetooth headset for ps3 and it wont connect and let me scan. it was made in 2007. Any way I can fix it??
did it ever work for you are you holding the power-sync button long enough on the bt headset's load up light should stay solid or keep blinking till it sync's up start the ps3 bluetooth settings to start looking while you start to connect it hope that helps if not the bt set could be faulty try syncing it to a cell phone
Nov 17, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Headset
you haveto have the bluetooth connectivity serch for th device. one the device is found then your phone can be linked to that bluetooth adapter.
Jul 15, 2009 | LG HBM-710 Wireless Headset
Palm TX, Dell 6300 Laptop, can see each other through Bluetooth but will not connect. Want to connect to sync clocks.
Have you checked your hotsync settings and bluetooth settings to make sure that you are using bluetooth sync and not the serial connect. Palm devices can also share LAN/Internet over bluetooth.
Jul 18, 2008 | Apple iPhone 3G
H350 bluetooth headset can't connect to laptop any solution connect to a motorola bluetooth headset how do I get my Motorola H350 bluetooth earpiece to work with my laptop?
Do you have the Jabra bluetooth part that goes into your computer? You have to go to your phone settings under bluetooth and make it sync up. Your phone will sync, not your headset. You are trying to sync the wrong thing.
May 04, 2008 | HP Pavilion dv6000z Notebook
Can't connect
First click on your upper left Shortcuts softkey Next Scroll up to the Bluetooth menu & hit Select Now Click on Find ME you will have 3 minutes for the phone to find the headset. Now push and hold the hangup button on your headset It will flashes red then blue alternatley Your phone, will ask you if you want to pair up with the headset, Enter the key which is 0000 on your phone it will say Confirm that it is connected.
Mar 01, 2008 | Plantronics Explorer 320 Headset
Activesync via bluetooth
Click on Ipaq wireless
turn on the blutooth
Click on Manager
at the bottom click on new
and then click active sync via bluetooth and go from there
Jan 02, 2008 | HP iPAQ HX2490 Pocket PC
iPhone Apps Logo
Top Apps Experts
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
