Question about Sharp AR-164 Copier
My shared network usb printer is not printing!!!
I have a usb hp 1320 printer series that i want to share. i have selected the share this printer option but if i try to print a document from another computer it is not printing. It is only printing those documents form the computer that the printer is plugged on. Please help! what do i do.
  • jackiekym Apr 24, 2009
    My network is configured as i am trying to share the usb printer via a a lan network in my organization.
Have you configured your home network yet? This must be done first, and then you can connect to the printer. I have recently provided a solution to first configure a home network, then connect to a printer. Here's the link to that post:
http://www.fixya.com/support/t2061590-2_computers_1_hp_printer_am_trying
Please let me know if this helps, and rate my solution ;)
Posted on Apr 23, 2009
  • Anonymous Apr 24, 2009
    Did you perform the "sharing procedure" as described in the thread I provided?
Printer HP Photosmart C5180 Series cannot be contacted over the network
Check with HP for a Windows 7 driver for the printer. HP Ink Jets require proper drivers to work correctly. Once you have downloaded and installed the drivers try connecting again.
If you have installed the drivers and Windows 7 still refuses to "talk" to the printer, you may have to adjust your advanced network settings as well. Open up the Network and Sharing center, click on advanced sharing settings and make sure file and printer sharing is turned on. Also check "File Sharing Connections" and enable file sharing for devices that use 40 or 56 bit encryption.
If that fails to work you may need to speak with HP support for further assistance.
Feb 23, 2012 | HP Photosmart C5180 All-In-One InkJet...
Hello , I need to know if hp-laserjet p2015 printer have a "built in" network card ? if not how can i share it between two computer by using a switch ?
HP Laser jet P2015n & P2015dn models having network facility, there is no option to add on network card for this series.
1. Install the printer locally through USB in one system and share it to others if its non "N" printer.
2. You can connect use network to USB convertor to print thorugh network. pl see the link for one of the sample product..
http://uk.shopping.com/Conrad-USB-2-0-NETWORK-ADAPTER/info
Sep 20, 2011 | HP LaserJet P2015 Printer
Hp deskjet 550c trying to print from network But I am on windows 7. Printer is on xp. Can't find driver or fix to run printer on network
Use my published guide to install the latest drivers for all computers on the network. It is entitled
How to Install the latest drivers for Hewlett Packard Printer!!!
The drivers need to be installed on all computers in the network.
Then once the drivers are installed all you need to do is to navigate to the Windows control panel and double click printers and faxes on the computer that the printer is connected to.
Now right click the your printer and select the option Sharing, this will allow you to share the printer on the network.
Click the lower circle to share the printer.
Then when you print from another computer on the network, be sure to select this shared printer as the printer to print to, or set this shared printer as the default printer by right clicking the printer and selecting the option to set as default printer.
Please be sure to rate this session.
Take care!
damnor01
Jun 01, 2011 | HP DeskJet 550c InkJet Printer
I have 1320n printer but i cannot print in network plz solve
YOUR PRINTER IS NOT SHARED ON THE NETWORK FIRST GO TO THAT COMPUTER WHERE IT IS INSTALLED AND GO TO "PRINTER AND FAX" OPTION RIGHT CLICK ON 1320N PRINTER THEN SELECT PROPERTY THEN SELECT SHARE OPTION AND CHECK THE OPTION "SHARE THIS PRINTER".
Jan 19, 2011 | HP LaserJet 1320 Printer
How to add NIC in HP color laserjet CP1215 Printer?
If this model HP does not have an expansion slot for a HP Jetdirect Print server, then to use this printer on your network you have two options.
1. Connect the printer to a desktop computer on your network and set it uo as a shared printer. This means this computer and printer needs to be powered up for the other computer on your network to print to the shared printer.
2. Connect the printer to a print server that is connected to your network.
Nov 24, 2010 | HP LaserJet P2015 Printer
Hp printer lan setup
Right click on the printer, click sharing option on the context menu, select sharing tab, Click on the underlined words "If you understand the security risks but want to share printers without running the wizard click here", click the button "Just enable sharing", click on "share this printer", type the share name, Click on Apply and say OK. Your printer is ready for lan printing. Now using another system detect the network printer and select it.
(Note: It is assumed that your system is on the same network as another system and the printer is connected to your system)
Sep 05, 2010 | HP Office Equipment & Supplies
I have a hp PSC 1610 all in one printer, connected to a hp desktop computer. I have a lynsys wireless router connected for a wireless network in the house, the desktop is the main computer for this...
Two ways to do this:
Since this is a USB printer and not a network printer you have to create a "share":
1. On the main computer that has the printer attached, go to the printer properties (START, PRINTERS AND FAXES, Right-click on the printer icon and select "sharing"
2. Select the Sharing" tab and select "Share this printer" radial.
3. Enter a short name for the printer in the "Share Name" box, such as: HP1610
4. Save that configuration and remember the "Name" you gave the share.
At each computer on your network:
1. Go to the printer setup sceeen (see #1 above)... and "ADD A PRINTER"
2. Select "Network" printer (not local printer)
3. Select "search for printers and the HP1610 will appear on the list.
4. Select it and follow the instructions from there...
Hope this helps!
Sep 08, 2009 | HP PSC 1610 All-In-One InkJet Printer
Print sharing
No matter how you slice it, if you want to share the printer, you will be creating a network. If I remember this printer correctly, it has an Ethernet port to connect to a network or USB to connect ot a computer. If your router supports wired connections, you can connect it there and just inistall drivers on each device and selec tthe network option. If not, you will probably want to connect it via USB to your desktop machine and enable print sharing on that machine. Te enable printer sharing, open up the Network and Sharing Center. In the Sharing and Discovery section, turn on the option for Printer Sharing. You will still need to install the XP driver on the netbook and select the network option, but give it the proper network location (ie.\\mycomputer\this printer).
May 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Wireless printing
I assume you have a wireless network set up with a wireless router, since you said you have a wireless laptop.
You need to share the printer on the desktop. You also need to set up both computers to be on the same network (for example, WORKGROUP or MSHOME, or a name of your choosing).Once shared and on the same network, you can go to the laptop and add a printer--just tell it that it is a network printer.
A caution--to work without further hassle, both computers need to be running the same version of Windows. If not, you'll need the driver disk for the system on your laptop.
Jan 16, 2009 | Computers & Internet
Sharp AR-164 Copier Logo
311 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
