Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
I have a Jenn air electric range sve87600w (with touch panel) and no manual. I am trying to figure out how to program time bake.
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: jenn air jgr8850adw won't bake
This usually is an indication of a bad igniter. If this is the standard glow type igniter, it could appear as if it is working, but may not be providing enough current to open the gas valve. This is a safety feature on gas ovens. The gas valve requires a current potential of .32 to .37 amps through the igniter before it will open and allow gas to flow. This prevents gas leakage if the igniter fails to light. The reason your broiler works is probably due to the fact that the broiler gets used less and the igniter is probably in better condition. You can test this theory, if you like, by swapping the igniter for the bake and broil burners to see if the symptoms change. Or, you can simply just replace the bake igniter with a new one. Make sure you secure the power before attempting, though. You shouldn't have to turn off the gas for this. Chances are that's all it is. I hope this helps you.
Posted on Jul 14, 2007
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Posted on Jan 06, 2009
SOURCE: Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Posted on Aug 12, 2009
SOURCE: How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Posted on Oct 11, 2009
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
https://www.repairclinic.com/RepairHelp/FaultCodes/26/Range-Stove-Oven
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
After baking and trying to set time bake a week ago, the range won't turn on at all. Nothing happens when we press bake, broil, convect bake, etc. The clock, lights, fan, timer and cook top still work.
the oven controller in the main service/selection panel has either a bad solder joint on the circuits or the start realy for the oven on the same circuit board is bad and you have to replace the whole panel you cannot just buy the relay
Jan 20, 2010 | Jenn-Air JDS9865BDP Stainless Steel Dual...
The convection fan does not work anymore in any of the following situations: Convect bake, roast bake or quick preheat. What could be the cause? Can we get the electrical schematic for this...
This is your convection motor that's gone out. If you will call or email us, we;ll be sure to send the correct motor along with the schematic for your Jenn-Air range. This is an easy problem to solve so please get in touch with us soon so you can get your oven running right again.Remember...Thanksgiving is just around the corner, so lets get you cooling again real soon. We hope to hear back from you real soon,
Sep 29, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Jenn air touch panel on oven beeping and flashing
throw the jenn-air out.
purchase something from another company that cares about their products.
I have had the same issue, twice. my wife managed to melt the touch pad by baking and using the burner at the same time. this has happened to countless purchasers of jenn-air **** appliances. they should be sued and forced to fix their faulty design
Aug 29, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Jul 03, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
Jan 14, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
115 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
