Question about RCA (DTA800B1) Video Converter
Trying to program my rca converter box with a dollar tree fc 6 n 1 universal remote
SOURCE: converter box codes for rca universal remote rcr3273/3373 for zenith or lg boxes
if It is similar to most RCA universal remotes, to get the code follow these steps(Manual code search MAy take awhile):
1:Manualy turn on the component that u want to control
2: press and hold the component key (ie SAT while holding SAT press ON-OFF key(button) for three seconds until all of the components light up and release the keys(button).
3: keep pressing ON-OFF key until your component turns off.(Note may take awhile)
4: one the correct code is found hit the STOP key and it will save your component IF YOU DO NOT HIT THE STOP KEY THE CORRECT CODE WILL NOT BE STORED.
Hope this works
Posted on Oct 26, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: I have this RCA Universal remote (RCU410WMS) and I
RCA's site list codes 25 and 006 for Magnavox cable boxes. Maybe one of these will work for the converter. The RCA site has a link so you can look up codes. Click on "find your remote control codes here" and pick your model number, then the type of device you want to control. If the codes I gave don't work, maybe try some of the other brands of cable box codes. You might find one that will work.
Posted on May 05, 2009
  • 1218 Answers
SOURCE: Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
http://dtvconverterboxes.blogspot.com/2009/05/rca-dta800b1-owners-manual.html
Posted on Dec 28, 2009
  • 73 Answers
SOURCE: RCA universal nor cable remote will program RCA L40FHD41 TV
might be able to use the cable co remote and autosearch thru the codes, but its too hard to explain, the cable tech should have ran that procedure. unfortunately, rca has 50 million models. it is common to have a tv and yes rca for sure, to not take the codes. sometimes the tv is too new for the cable company remotes to work. i am leaning toward the tv too new theory. give it six months and i bet there will be a new remote version.
Posted on Jan 21, 2010
  • 3 Answers
SOURCE: I have a rca universal learning remote I need code
Do a search for remote codes. They're online.
Posted on Oct 23, 2011
Program my rca remote too my rca converter box
If your RCA remote is universal, you can do a code search to find something that will work.
Oct 08, 2016 | RCA Televison & Video
I have a rcu404 universal remote. I'm trying to program it to my apex502digital converter box
Unfortunately, the RCA RCU404 was programmed in 2003 before the digital-to-analog converter boxes were released. It doesn't have a code for any brand converter box. The Apex converter boxes were listed at Amazon in 2004. See http://www.rcaaudiovideo.com/remote-code-finder/?sku=RCU404&productType=Digital+TV+Converter+Box to search for all available device codes. Change the Product Type via the drop-down menu for other device codes.
Most universal remotes code lists are limited to devices that hit the market 6 months before the remote was programmed and older devices. I wish that I had better news for you. A universal remote that was programmed later (2005 at the earliest) would be more likely to support the converter box and let you consolidate all of your remotes.
I hope this helps.
Oct 05, 2016 | Universal Televison & Video
Venturer. How can I use it with an RCA STB?
If your Venturer remote is universal, you can use its code search feature to find something that can handle some or all functions of your RCA STB. If a search through all codes stored in the remote fails, you may have to try another universal remote such as an aftermarket RCA.
Apr 06, 2016 | Televison & Video
Codes for a rca converter box remote control
Try using directv's :remote control code search engine)search for "Directv remote control programming" enter your device type and it will give you the most recent code for your device
Mar 08, 2014 | RCA Universal Tv Digital Converter Box...
I want to program my greenbrier 6 in 1 remote to my rca digital converter box
These are the setup codes by model.
RCA HD65W20 ............................ 0658
RCA PSHD105 ............................. 0636
RCA DTC-100 ............................... 0636
RCA DTC-210 ............................... 0636
Oct 18, 2012 | Audiovox Universal Remote, NaviLight 6, 1...
RCA Universal Remotes and Digital Converter Boxes
A converter box will not work you need another advanced remote for that try www.remots.com and see if they can match you up with a solution. Thanks and please rate.
Aug 21, 2009 | Televison & Video
Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
Apr 21, 2009 | GE JASRM24912 Remote Control
RCA (DTA800B1) Video Converter Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
