Im trying to find a CA9005 manual conia split system air conditioner
SOURCE: Split System Air conditioner
There normally two types of leakages from the wall unit.
1.The warm air in the room when comes in contact with the cooling coil of heat exchanger (consisting of fine fins where compressed refrigerant evaporates) looses its heat & cannot retain the same moisture content at lower temperature at the point of contact with evaporator. There is a provision of a drain pipe to carry this condensed water to outside water drain. So if the drain pipe is choked or the coupling joint of the drain pipe at the bottom of cooling coil is not proper, there will be water leakage, This can be easily attended by physically looking at the fittings.
2.The second problem can be the leakage of the refrigerant. If there is second type of problem, then there will be very little or no cooling irrespective of continuous running of air conditioner. This can be easily checked by feeling the temperature of outlet air from the air conditioner.
Conclusion-As you have written that there is leakage from the air conditioner, but you have not written whether it is visible or invisible. If the leakage is visible, it is problem number 1 & if it is invisible, it is problem number 2.
If you are not satisfied you are free to ask for more explanations.
Posted on Jan 29, 2008
Johnny Reb
SOURCE: Remove and relocate split air conditioner
The simplest way of explaining this is as per the following. On your outdoor compressor unit there should be two pipes, one smaller diameter [high pressure] and a larger diameter pipe [low pressure]. Turn your A/C on inside the house and then shut off the smaller diameter pipe. Run the unit for a around 3 to 4 minutes and then check if the cooling is reducing from the unit inside the house. When you feel room temperature air [not cool] being emitted from the indoor unit shut off the larger diameter pipe and turn off unit. Isolate electrics, disconnect A/C piping and immediately seal the piping with good quality tape to prevent egress of dirt. When re-installing a quick purge of gas is usually only required to clear the lines if they were sealed properly and kept clean. Ideally running a vacuum pump is recommended but if care was taken then it may not be needed, as in many of my installations.
Posted on Nov 13, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
  • 81 Answers
SOURCE: Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Posted on Oct 25, 2010
Is Conia air conditioner CA24001 split system reverse cycle I cannot get heat?
Sounds like either bad reversing valve or to get you going during the summer someone may have wired it to stay energized all the time which would have been a thermostat problem.
May 30, 2016 | Dometic Heating & Cooling
How do I turn on heat on my air cond. Conia split system?
if it is set up for it
no heat on/off button on ours
we increase the the temp setting till warm air flows
May 30, 2016 | Heating & Cooling
Conia Model - CPA12020 Air Conditioner; does anyone have the manual for this? or at least know how to fill it with water? or if it needs water?
as we have no make or model listed how could we possibly guess . I have seen and owned several tho and none even had to have water put in them .
Nov 20, 2015 | Heating & Cooling
Conia split system operating manual
Not sure if this is what you are looking for. A Make and Model would be a great help in finding the information that you are looking for. So we at West Palm Beach Air Conditioning would love give you a hand.
Manuel:
https://highcongtana.files.wordpress.com/2015/10/conia-air-conditioner-manual-ca24003.pdf
Oct 16, 2015 | Heating & Cooling
Please help me reset conia split air con ca2422
If you need to reset a pressure switch...then the refrigeration system needs to be checked. High or low switch looks like about a 3/4 inch Diameter plug with 2 wires & a red manual reset switch in the middle.
Dec 13, 2013 | Heating & Cooling
What is an error 3 in conia split system
shut down the energy alimentation for 2 minute ,but if the defect persist error it show again
I have a conia split system and e3 has shown up on inside unit
Indoor unit air sensor defective. Replace it. Thanks.
Feb 04, 2011 | Heating & Cooling
Conia 3 HP, 5 yr old air con/ condensation from wall unit
NOW, THE EVAPORATOR COILS NEEDS CLEANNING OR THE DRAIN LINE PLUGGED,OR JUST CLEAN THE FILTER.
Nov 30, 2009 | Heating & Cooling
I have a sanyo A/C split system and im looking for
google it that info here will cost.Tom
Jun 21, 2009 | Heating & Cooling
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
