Question about Digidesign Digi 002 Rack FireWire Pro Tools LE Music Production System Volume License for PC, Mac (MX002R)
How to connect from the digi 002 interface to the computer
3 Suggested Answers
crogers2009
  • 31 Answers
SOURCE: Which firewire cable do I use with my Digi 002 console?
If you are using a desktop comupter, you will need any 6-pin to 6-pin connection. If you are using a laptop, you will need any 6-pin to 4-pin connection.
Posted on Jan 12, 2009
  • 3 Answers
SOURCE: My Digi 002 Rack is "Clicking" (the actual unit).
power supply issue , voltage is too low to feed digital part of the sound card. www.rainbowaudio.nl has come with the solution as the part of the modification to built the new power supply for digi 002/003
Posted on May 23, 2012
How to install the drivers for digi 002 on windows 7
Here is the official AVID page regarding the digi 002 drivers: http://avid.force.com/pkb/articles/en_US/Download/Digi-002-003-Drivers
Feb 05, 2013 | Pro Tools Digidesign Digi002 Mixer Avid
Hi
First thing to do is a hard reset. Merely unplug the power cord for 4 hours, then power up again.In order to dissipated the remaining current stored in the memory and disconnect all unit connected.
Regards:
votit
Feb 08, 2011 | Digidesign Digi 002 Rack FireWire Pro...
Hi i have digi design rack 002 with pro tools le
Try the other port on the 002. If that doesnt work, I recommend trying the 002 on a computer that does have 400 to see if it will connect then.
If it doesnt, then you may have a couple blown firewire chips inside your 002. It happens, and can be fixed.
Jun 29, 2010 | Digi 002 Rack FireWire-based Pro Tools LE...
I want to hook up a an interface to a mackie mixer. What is the common denoinator to hook up, let's say a digi 002 and a mackie mixer so i can have a mac computer with pro tools operational with also the...
you can just piggyback the mixers - take the outputs from the mackie mixer (assuming it is NOT a powered mixer) ... those should be line level outputs - send them into a line level input on the digi 002 and then set that channel on the digi 002 and once set, just leave it, and control the mackie channels individually ... should work fine ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Oct 14, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
My ProTools LE Digi 002 rack stopped connecting to my IMac.
clean the ribbon cable connection on the dc power harness with contact cleaner. i had the same problem. this fixed it.
Feb 14, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
Jan 12, 2009 | Digidesign Digi 002 Rack FireWire Pro...
Digi design 002 rack
Is your firewire cable good? Sorry, I know this is obvious.
May 08, 2008 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi 002 rack
easy. Your clock got screwed by one of your audio programs in you system. It Happens when sample rates are mixes up. Leave your digi 002 on it does not set itself other than the factory sample rate setting when primarily switched on, which will remember its last setting if mixed up in an attempt to recover. Leave it on turn your system on. Then turn your system off. Not the digi. just your pc, mac. The software utilizing the previously screwed up sample rate will or should be reset. thus resetting your digi 2 to its factory 44. If it does not work check your software settings for any audio software set as default to run when pc is started ans make sure they are set to play back 44. Never turn your pc off when a program using your digi faulters.
Sep 08, 2007 | Digi 002 Rack FireWire-based Pro Tools LE...
Digidesign Digi 002 Rack FireWire Pro Tools LE Music Production System Volume License for PC, Mac (MX002R) Logo
21 people viewed this question
Top Digidesign Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
