Question about Cannon i70 Printer
Cannon Bubble Jet 4100 Printer
My Cannon BJ 4100 is 10 years old, I gave it to my mother for her computer, and after seting it all up, and it makes all the sounds that it wants to start printing, but the on light flashes on and off. Is it out of ink? or something else? I used the disks to set it up. Help?
  • Cannon Master
  • 705 Answers
Does the machine beep 5 times and flash both the power and error lamps? If so then the Waste Ink tank/pad is full and needs to be cleaned and the printer counter reset.
Posted on Sep 25, 2007
SOURCE:
Where can I find carteidge holders for BJC-80 Cannon printer
Hello JBM,
Please press the cartridge button and the cartridge holder moves to the center. Gently press and pull the front cover toward you. Press the green tab on the front left edge of the BJ Cartridge cartridge holder. This releases the BJ cartridge. Lift the entire cartridge out of the printer. If installing a new BJ cartridge, take it out of its protective packaging. Peel off the protective foil, and lift the cartridge out. Lift off the orange cap from the print head. Then remove the orange tape.
Jun 28, 2011 | Canon BJC 80 InkJet Printer
Hi I don't have a user manual for the Cannon BJ-W9000 large format printer and I have an error code that e2102
Print-position sensor calibration warning
Error occurred when calibrating the print-position sensor before the paper-width
detection sequence.
cHECK SENSOR
Jun 23, 2010 | Canon BJ-W9000 Copier
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    My dad's computer won't turn on
    chessmaster2 has some good points... you need to make sure your computer is getting power first... a lot of motherboards have a tiny green light that is on when computers are plugged in but off. If you are not sure what a mother board is, then you probably can't do much more than what chessmaster2 gave you. By the way, if this computer is old, the majority of computer problems that you've described are because the power supply is bad. A lot of people don't regularly (2x a year) blow out the dust from their computer. So it collects dusts which then block the ventilation holes, so things overheat and go out, and typically that is the power supply.
    Nov 26, 2008 | IBM Aptiva E 572 (2174572) PC Desktop
    Need software download for ip3000 series
    Hi ljk1138,
    The Cannon BJ ip3000 driver software can be found here:
    http://www.download.com/BJ-Printer-Driver-Canon-Pixma-iP3000/3000-2116_4-10555913.html - I hope this helps you out, if not, hit me back, we have other options to offer.
    Thank you for using FixYa.com
    Sincerly, cyyyd7
    Oct 09, 2008 | Cannon Office Equipment & Supplies
    Canon BJ 200 InkJet Printer Problem
    Hello Ruth:
    Somewhere on this website should be my comments on your problem but I can't find them, so here's a repeat. Sounds like the print head is clogged. With power on, press the Online and Print Mode buttons simultaneously until the lights to the left of the Online button blink. Normally, this takes a few seconds. This is the recommended cleaning procedure for this printer head. If no success, repeat this a few times. If no success, replace your ink cartridge with a Canon BC-02 black ink cartridge (if not already using this) and use the above cleaning procedure before trying to print. If unsuccessful, try a printer repairman.
    Aug 29, 2008 | Canon BJ 200EX InkJet Printer
    Instalation of cannon bj 250
    http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=329&modelid=6729
    follow this link and in the drvers/software selection choose your OS....Wait a few second and you'll be transfer into the driver area. Download the driver. Be sure to install the driver before connecting your printer to your PC.
    Apr 05, 2008 | Canon BJC 250 InkJet Printer
    95 people viewed this question
    Top Cannon Office Equipment & Supplies Experts
    Ekse
    Clive
    Clive
    Inky Fingers
    Inky Fingers
    Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
