Cadex Battery Tester fault
Im getting failure on station station number 2 on my Cadex C7200. The error message is "HOT WAIT 49degC". I can do with a schematic if its available Thanks
3 Suggested Answers
SOURCE: Software fails to install for
I finally got the software installed by uninstalling it and unplugging the USB cable on the printer, then reinstalling the software and reconnecting the USB cable. Now every time I try to bring up HP gallery I am asked to put in the disc that has the creative projects file on it. I have tried that several times and it doesn't work. After I hit the delete key on the cancel window several times I finally get the HP gallery to come up. I think HP needs to fix that part of the program disc.
Posted on Nov 28, 2008
Riztech
  • 731 Answers
SOURCE: My HP photosmart c7200 is showing System Ink
Please click the below link to find the troubleshoot information about this issue.
Solution Click here
Regards,
Riztech
Posted on Mar 08, 2010
Any computer can tell about remot
remote what? and no YEAR CAR> really?
radio, head end ?, key fobs. what ?
why not post the symptoms. why not say that.
if this is RKE , remove key entry issue?
and you lost the 2nd one that came with car? did you, (more symptoms?)
is it a door lock failure or car starting or running failure.
no there is no tester, (dealer has one) but no real tester
at my local auto store they have this POS tester that only tests
the lock transmitter for RF transmission energy, near worhless test if ever, did you replace the RKE remote battery yet, (second fob lost)
making a real tester would be hard with 10,000 different car key protocols, in force. very very hard to do. and the new cars
have secret ROLLING encrypted key messages. (impossible )
ON my car (a very strict 08) you can make a 3rd fob or transponder key at any time.
if you lost the 2 spares you are screwed. never cars with only 1 or 2 fobs, on mine its 3 fobs min. and 8 fobs max.
i can run 1 real fob and 3, $13 key only transonder keys and that works too. making me DIY full time, forever.
not posting year is big error here.
vast generational change by years.
to bet best help post car make , year, and engine size if engine question. then state what is wrong.
my car will not crank, or cranks and runs for 2 seconds. or
my IMMO lamp shows FAULTS (read the operators guide IT TELLS you what to do with Immoblizer active warnings, yes, RTM)
May 19, 2014 | Hyundai Veracruz Cars & Trucks
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
Kyocera error c7200
km 6030 machine have a code on screen c7200 so how i solve it
Dec 18, 2013 | Kyocera Km-6030 With Feed, Finisher, Bank,...
Error 0xc05d0082
Remove cartridges,switch off the printer, dis connect usb cable & power cable.. wait couple of minutes..powering it wait till message appears for consumables.. install consumables., install usb cable.. check...for message.. Remove CMOS battery mounted on formatter wait for couple of minutes, power it then check..
Jan 31, 2012 | HP Photosmart C6100 All-In-One Printer
Uniden DSS7855+1, flashing ''welcome! please wait...'', wont work
This is not a direct solution to your problem, but a workaround for a similar situation. I have two headsets and two charging stations. One of the headsets was stuck with the message ''Welcome! please wait''. When I put the phone on the charging station it usually sits on nothing would happen, but when I put it on the other station the phone came back to life. The non-working charging station will still charge the phone so it is worth keeping.
Mar 04, 2009 | Uniden Lands Phones
57.70 error messages for hp printer lj 9500n
Error 57 is generally a fan fault ; on the LJ9500, 57.70 is indicating a fault with the fuser fan in particular.
plz do rate this post
Nov 25, 2008 | HP LaserJet 9500n Printer
I am receving error messages E301 or E100
E100 - 001 and 002:
BD error has occurred.
• The laser unit has a fault.
• The BD PCB has a fault.
• The laser driver PCB has a fault.
E301:
The scanning lamp intensity has a fault.
• The scanning lamp has a fault.
• The CCD PCB has a fault.
• The DC controller PCB has a fault.
Seems to that you have issues with dc controller pcb
Oct 04, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Ink system failure erorr 0xc18a0306
Although it did not work for me, HP offered this as a solution. If it does not work, HP indicate you have a hardware fault that can only be fixed by a service engineer repair.
1. Get the unit into the “Support Menu” by following the steps below :
A. - Press and hold the “left arrow” key.
B. - Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release the “OK” button.
Display should say “Support” and display the FW rev (something like R0616R)
2. Press and release the right arrow button until the display says “System Configuration Menu”.
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Mar 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
90 people viewed this question
jasbo
jasbo
