Question about HP Compaq Business nx6125 Notebook
The sd card reader in hp compaq nx6125 is not working
Any memory card is not recognised and unreadable
  • 1 more comment
  • perisicdoo Apr 23, 2009
    all cards i try are not working in the laptop... earlyer when I put one in the laptop opens a window with the content on it.
    the card itself is working fine... tnx for your coment :)
    the card it self is ok
    the card reader is installed in the case itself in this model
When the power button is switch on, light come on and go out as expected, drives spin and fan starts. Then after a couple of seconds, there is a small click from inside (sounds like HDD) and the fan stops, then after 2 seconds more, fan comes on, then 2 seconds later goes off again, this repeats itself about 15 times. During this on/off of the fan, the HDD light and the DVD drive lights flash in rhythm with the fan going on/off. After the 15 or so cycles, the HDD light and fan both say on. During the whole process from start to finish, the screen is completely dead, even attaching an external monitor doesnt bring anything up
Posted on Apr 07, 2011
    Sergeant:
  • 199 Answers
Dear it is damaged...please replace....when this message show then memory card is damaged and not readable or not writeable.
Posted on Apr 23, 2009
  • Aftab Nawaz Apr 23, 2009
    DEAR CHECK YOUR usb PORTS.IF STILL PROBLEM OCCURED THEN YOUE USB DOES NOT WORK OR UNPLUGED
Its not recognizing my sd card reader
Make sure you can see the Secure Digital host controller and
Texas Instruments PCI GemCore based smartcard controller in the Device Manager. If its missing, re-download the drives from HP.
If you are trying to use a SDHC Memory Card in the reader,
you will need updated Win XP TI drivers as the ones on the HP site
do not support the newer memory cards.
This goes for the nx5000's nx6110's nc6120's and nc6320's.
Updated XP TI drivers are needed
May 06, 2010 | HP Compaq nc6120 Notebook
Memory card error message when sd card inserted
Try to read the card in another card reader or a computer that has a reader slot. If it can read it then you may need to download a driver for that card to enable your HP to read it. If on the other hand your computer can read identical cards made by the same SD manufacturer as your unreadable SD card then there may be a problem with the connection of your pc to the pins in this particular SD card. In that case, you need to transfer the files from the card to another device and load them to your pc.
Jan 09, 2010 | HP Photosmart 3210 All-In-One InkJet...
Unreadable memory card!!!!motorola krzr k1
you may have to buy a memory card reader, plug it into your computer and format the memory card before it will work in your phone, or your phone may require a different format of the same card, for instance some camera's take SD cards, and some take the HD/SD card, and they are not interchangeable, the SD will not work in the HD/SD device and vice versa..........hope this helps........
Aug 22, 2009 | Motorola Mobility Car Charger For KRZR...
Casio exilim z750 sd card unreadable
If the memory card is not recognized in the PC or it is impossible to access the data on it, the controller on the card is damaged. There is only one way to get the data back, unsolder memory chips and directly access their raw data with a programable chip reader. Software can't help, that is a physical damage! Have a look at: CF xD SD memory card/stick photo recovery
May 08, 2009 | Casio Exilim EX-Z750 Digital Camera
Laptop not reading camera memory card
Hi Lavanya,
Some machines can't read large capacity Sd cards my old Hp Nx6125 could only read max 1Gb. If your card is larger then you may need to purchase an up to date external card reader, most read up to 8gb and are not expensive.
Hope this helped? if it does please remember to press the Blue button for my FREE effort!
Paul 'W' U.K.
Jan 29, 2009 | Acer Extensa 4620 Notebook
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Sd reader problem
Driver for the SD reader can be found on the nx7000 page by Compaq (but not on the nx7010!!)
Nov 28, 2007 | HP Compaq nx7010 Notebook
HP Compaq Business nx6125 Notebook Logo
671 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
