Question about Watches
How to set time in ODC 130 - Watches
HOW TO STOP ALARM SYSTEM IN AJANTA QWARTZ ODC 120 MODEL WATCH. ALARM KEEPS BEEPING EVERY DAY AND I DONT WANT THAT.
Ask the maker via the Contact page. Looks cheap and nasty!
http://ajantaworld.com/index.php/products/time-products/picture-clock/digital/lcd.html
Sep 28, 2015 | Watches
How to set time for Casio Baby-G BGA-130
Look up the model on Casio.com and download the manual.
You'll need the four-digit (or three-digit) module number marked on the back cover of your watch.
Jan 05, 2014 | Casio bga-130-1b baby-g bga-130-1ber
Why my watch not display or blank after keep for long time
As this is a solar powered watch,there is the PS (Power Saver) function.
If PS is ON (which is by default) display will become blank if watch stays in the dark for sometime.As you bring it back in light,display will be activated automatically.You can switch PS to OFF and have display activated all the time even in dark (not recommended) but in this case battery will run short quickly.And this watch needs power as it is a multifunction watch + atomic time setting.
Nov 10, 2013 | Casio PRG-130T-7VDR PRG-130-7 Protrek...
How to adjust the correct time of ajanta quartz ODC-120
move the plastic button at the back slightly to the right side where it says "Time" and than adjust the time by pressing 'Mode' and 'Up/Countdown' buttons
Oct 14, 2013 | Watches
I own a Ajanta Quartz odc 170 wall clock but have misplaced the operating instructions. Can someone please help me with the setting instructions. Many thanks. Joshua
There is a sliding button on the back side to the right of inner frame. The slider has "Normal -> Time -> AL SNZ -> CountDown->Timer" marked on it.
You need to move that button to time basically to the right side and then user up and down buttons to adjust the time.
Hope this helps.
-- Anant
Jan 29, 2013 | Watches
Sector 130 watch strap
Hey! Just go to this website and tell you how to adjust a rubber band watch and how to replace it!
www.watchbandsonline.com/qanda.asp
Hope it helped! ^-^
Sep 17, 2012 | Sector Expander 130 Chronograph Alarm Mens...
I am unable to set the time because the function button (top left over the 10 O'clock position. I had a local watchmaker tell me the button moves, but it has no effect on the electronics. Casio has an...
I have a different model of Casio but I suspect that the operation is the same.
To change DST you should press the button (8 O'clock) to give world time. This should be showing your city.
You should then use the button you mention to toggle between DST & ST. (ST is no DST display!).
If this does not work and you wish to read through instructions for your particular model, then go to casio.com, select "support", and under "technical support" select "manuals", then "watches", agree terms, and the select "watch manuals archive", insert the required number off the back of your watch and download the instructions.
Jan 28, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Watches Logo
312 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
