Question about Acer Timelinex 4830t 14" Laptop Intel Core I3 2.5ghz/4gb Ddr/500gb Hdd/dolby
Starts up will not let me log in - Acer Timelinex 4830t 14" Laptop Intel Core I3 2.5ghz/4gb Ddr/500gb Hdd/dolby
Acer starts has xp home. goes to log in page, pointer feezes unable to do anything.
If it works normally in Safe Mode, that is the place to run antivirus checks in depth, and also use Malwarebytes AV. Do updates for these before running.
If this fails, come back here for more help
Apr 05, 2014 | Acer Computers & Internet
Tip
Annoyed that your Num Lock key isn't on when you start your PC?
Here's a quick tip to ensure your numlock key stays "ON" by default when the computer starts.
1. log off your PC to the Ctrl-Alt-Del screen
2. Turn on the NumLock key
3. Hit Ctrl-Alt-Del (like you are about to log on)
4. Don't log on, hit the "shut down" button to turn off your PC
This saves the numlock key in the "ON" position by default when the PC starts.
on May 20, 2010 | Computers & Internet
Facebook not loogging out
Try logging out in on another pc and it will log u out on that one
Nov 24, 2012 | Computers & Internet
Error 1203 on a Dell Printer - what is this?
2080 1203 2055...Critical / Failure / Error...2080 1203 2346The Storage Management Service performs alert monitoring and logging. By default, the Storage Management Service starts when the managed system starts up. If you stop the Storage Management Service, then alert monitoring and logging stops. Alert monitoring does the following:
  • Updates the status of the storage object that generated the alert.
  • Propagates the storage object's status to all the related higher objects in the storage hierarchy. For example, the status of a lower-level object will be propagated up to the status displayed on the Health tab for the top-level Storage object.
  • Logs an alert in the Alert log and the operating system (OS) application log.
  • Sends an SNMP trap if the operating system's SNMP service is installed and enabled.
    http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=Error+1203&cat=sup&x=10&y=12
Mar 23, 2011 | Vacuums
Windows xp when i log on it starts to log on then it starts logging off even in safe mode
Try disabling password requirement so that when you turn on the machine it will go straight to the desktop and bypass the logon screen.
Feb 21, 2010 | Dell Inspiron 530s Desktop Computer...
When computer starts up i log on to user account it then starts and then says logging out how can i get around this
Login with the Admin account you can do this in safe mode create a new profile for yourself.
Restart under this new profile if it works copy all the documents across from the old account you will have to do this with Admin account then delete the faulty account.
Jan 21, 2010 | Microsoft Windows XP Home Edition
My emachine won't log on to any user
1st u find out the machine is connected to domain or personal machine
Jul 01, 2009 | E-Machines eMachines Desktop PC
Cant log on to windows
hi, you can try to log on safe mode on your pc use the administrator account and system restore it.
May 04, 2009 | Computers & Internet
Window starts up but it dosent let me log in please help
Can you specify at what point it doesn't let you log in? Does it get to the log in screen? Make sure you have your Caps Lock button turned off, and your Num Lock key turned on, then try to log in again. Will need a little more clarification if the problem still exists after trying this. Hope this helps!!
Dec 27, 2008 | Microsoft Windows XP Home Edition
Acer Timelinex 4830t 14" Laptop Intel Core I3 2.5ghz/4gb Ddr/500gb Hdd/dolby Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
