Question about Samsung SF-760P
Samsung SF-760p FAX sexd and receive problems (COMM ERROR) after line change to Voip
SOURCE: Samsung SF-3100 Fax Windows XP drivers for pc
the star button push hard and operae
Posted on Oct 13, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Samsung SF-5100P
Machine will require fuser(hot bit at rear) replaced before it will operate, take to dealer for quote or if brave and 240v happy then buy a fuser and get your tools out rip off the covers and in the back you will find fuser assy.
link to service item fuser U.S.
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=JC96%2D01621A&search%5Fmodel=SF5100
Posted on Nov 14, 2007
leroyal
  • 2120 Answers
SOURCE: Samsung Laser Fax Machine SF 5100 Manual
What is your question?
Posted on Sep 05, 2008
leroyal
  • 2120 Answers
SOURCE: Samsung sf 560 fax display shows open heat error
You have a bad FUSER UNIT
Posted on Jan 15, 2009
xptareq2000
  • 1447 Answers
SOURCE: samsung fax machine SF 560R states 'comms error'
When it has no paper then your all incoming fax documents save memory,Insert paper in cassette box and press start key or memory check button.
Posted on Dec 09, 2009
The fax not sending only to one number. it show comm. error on the screen. all other numbers are ok
This sort of problem is very difficult to overcome as there are a few reasons as to why this is happening.
1. The machine at the other end may be a very old model and not compatible with yours.
2. It maybe in the third world where the line quality is still poor.
3. The other machine is not turned on or may have it memory full.
4. Your machine will need to have its speed reduced to overcome communication problems.
5. Your machine is transmitting to loud so the other machine hears it slightly distorted.
Its very unlikely you will solve the problem. Sorry.
Dec 07, 2015 | Samsung SF-760P
I have a samsung sf-760p i just changed the toner cartridge it is just showing not compatible toner cartridge but am using the original toner cartridge. so what can be the solution for this problem??
I suspect you think you are using a genuine samsung cartridge but its simply not. The machine is looking at the chip in the cartridge and its not genuine. I suspect your cartridge did not come out of a genuine blue and white Samsung box or its similar but not the correct one.
Dec 02, 2015 | Samsung Sf-760p Laser Print/copy/fax/scan
Sending fax displays comm.error
There are many things that can interfere with proper sending of faxes. Has anything changed in your office recently? Phones changed? Did you recently get DSL service from your phone provider? If so, you probably need a DSL filter on the line going to your fax machine. Try faxing to different faxes to make sure that it is not the person you are sending to that has the problem. If you are using Voice Over IP or VOIP phone, good luck, as older fax modems do not always play nice and you will likley need to speak with your VOIP provider to ensure they have their lines configured. If nothing has changed in your office then perhaps your modem has just failed, it does happen. A new cord between the jack and the machine is a a cheap test as well. If you have a telephone, unplug the fax and plug in the phone and see if you can make a call.
Sep 04, 2014 | HP LaserJet 2840 All-In-One Printer
Comm error message
PROBABLY BAD PHONE LINE, CAN TRY SOME OF THE FOLLOWING
SLOW DOWN THE RX TO 1700
TURN OFF ECM
INSTALL DSL FILTER EVEN IF ITS NOT A DSL LINE
MAKE SURE THE PHONE COPANY KNOWS ITS A FAX LINE
IF ITS VOIP IT MAY NEVER WORK WELL
RESEAT ALL CONNECTORS IN FAX 3900
TRY SETTING TO MMR
MAY ALSO BE PROBLEM WITH THE SENDING FAX MACHINEOR, THERE PHONE LINE
Jul 11, 2013 | Konica Minolta Minolta FAX3900 Digital...
Cant send fax
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 17, 2010 | Samsung SF-565PR/XST Printer
Samsung fax machine SF 560R states 'comms error' messages in memory 65% how do we print these messages out?
Dec 08, 2009 | Samsung SF-560 Plain Paper Laser Fax
Comm error on a VOIP line
Fax cannot send on a VOIP line unless the VOIP line has T.38 fax protocol service.
Sep 25, 2009 | Brother FAX-575 Plain Paper Thermal
Have voip and brother mfc 7420. error code 2001 and 2006
Get a new phone wire. Put a phone on the line and listen for static. Too many phones on one line will cause problems. If the phone line is going thru a surge protector, check the quality of the sound with it and without it, it may be damaged. Keep power wires away from phone wires, they cause static.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
Mar 29, 2009 | HP LaserJet 3055 All-In-One Printer
Samsung SF-760P Logo
620 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
