Question about Samsung star II duos GT-C6712
Ip address needed for samsung gtc6712 to connect wifi
4 Suggested Answers
  • 7 Answers
SOURCE: how to connect wifi in samsung S5233W in auckland. mac address?
If you want to see your samsung wifi mac address, just turn on your Wi Fi, then tap "Search", choose one of the AP(Access Point) seen in your screen and then tap "Details", then scroll down, find "Device MAC". Voila! It's your mac address below... ^^ good Luck!
Posted on Mar 01, 2010
SOURCE: Samsung Galaxy GT-I9000 keeps trying
  • Go into settings
  • Wireless and settings
  • Wi-Fi settings
  • Click on the menu botton and select advanced
  • Select use static IP
  • IP address would be a random IP address from your wireless router
  • Gateway would be the gateway address from your wireless router
  • The netmask is your subnet mask address
  • The 2 DNS addresses are your Default Ip address from your own router and wireless switch
  • If you have issues copy the details from the Ipconfig /all command from Dos
Posted on Jan 02, 2011
usman_stpk
SOURCE: USING SAMSUNG CORBY PRO CONNECTING WIFI GETTING
i already connect to wifi but when i want to access internet it says no response ...
Posted on Oct 18, 2012
I have had Wi Fi on my Kindle Fire and now it will not connect and keeps asking for an IP address
See if this article helps you.
http://classroom.synonym.com/ip-address-kindle-fire-15120.html
Jul 12, 2015 | Amazon Kindle Fire HDX 7
I keep trying to hook to my wifi and it wants to change my IP address continuously. I had to change the settings to "static" and type in my IP address. Unit connects initially and then reverts to an
Keep the router to supply IP address using dhcp mode. Increase the lease time to 24 hours and don't forget to bind your device mac address with the dhcp IP in the router. This way it will always get the same ip from the router.
Dec 30, 2014 | Computers & Internet
How do I set up the ecb350 as a repeater. I have an xfinity wifi that doesn't reach the whole house but I can connect with an Ethernet cable to the back of the ECB350 out in the area I need wifi acce
What are you using for your main router (xfinity wifi)? The best way is to set the ecb350 in AP Router Mode not a repeater since you have a rj45 cable long enough to go from one of the ports on the xfinity wifi router and hook it into the ecb350. You will need to know what your ip address range is for example if the xfinity is 192.168.1.1 then you want to assign a static address for the ecb350 to be 192.168.1.100 (assigned IP Address) You will also need the Subnet mask, Default Gateway IP Address, and Primary DNS and Secondary DNS of the xfinity wifi router. Then on the ecb350 you will need to configure the following with the info you go off the xfinity router:
Static IP Internet Connection Type Select Static IP to begin configuration of the Static IP connection. Account Name Leave Blank Domain Name Leave Blank MTU Auto IP Address ie: 192.168.1.100 (assigned IP Address) IP Subnet Mask Specify the subnet mask of your Xfinity Router Gateway IP Address Specify the gateway of your Xfinity Router Primary DNS Specify the primary DNS server's IP address of your Xfinity Router Secondary DNS Specify the secondary DNS server's IP address of your Xfinity Router Discard Ping on WAN Check to Enable to recognize pings on the ECB350 WAN interface or Disable to block pings on the ECB350 WAN interface. Note: Pinging IP addresses is a common method used by hackers to test whether the IP address is valid. Blocking pings provides some extra security from hackers. Accept / Cancel Click Accept to confirm the changes or Cancel to cancel and return previous settings. Note: Clicking Accept does not apply the changes. To apply them, use Status > Save/Load Hope that this help you.
Sep 10, 2014 | EnGenius ECB350 Wireless-N Indoor...
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
How do we correct a DUOS Samsung DNS Not available?
i had got this try may be this help you :
It is a problem due to DNS server ip address.If you configured ip address in mobile manually to connect wifi check the DNS address.If you have connected to wifi automatically means there is a problem of DNS ip in the wifi router configuration.Google has public dns of 8.8.8.8 if possible configure in Mobile and try it
Jun 20, 2012 | Samsung star II duos GT-C6712
We have a wifi at home.. But every time a connect to it it doesn't work or connect either it always says "DISCONNECTED!"
Try using a static ip address and use the information from the router's ip address. (ip address, dns, subnet, gateway etc.)
Another option is to reconfigure your router by going to the router's ip address(which you can find [if on a computer] in control panel> networking>change adapter settings>local network>properties>ipv4 address)
Mar 26, 2011 | Samsung Star GT-S5233 Cell Phone
My galaxy tablet cannot detect our wifi connection. it always says disabled and scanning, obtaining IP address but will not connect. ive turn of/off the unit and entered the passkey several times but still...
Does the WiFi router have SSID? Did it ever connect to other WiFi Access Point before? If not some say to set the Tab on Static IP and configure the router to allow the Tab's MAC address. Hope it helps.
Jan 02, 2011 | Samsung Galaxy Tab Tablet PC
IPod touch Wifi problem. I got a new iPod touch 4g and my dad got new pocket wifi so I tried to connect my iPod to the internet and it would work for about five minutes but then it would disconnect...
hi this sounds like the pocket wifi firewall or push is stopping you from connecting, it will show connection when the password is put in correctly, but unless your either ip, or mac address is registered with the unit it will not let you connect to the net, you will have to see if there is a start ip and an end ip address in the wifi unit, as this might have restrictions to ip address numbers..for example..wifi ip start address might be 192.168.0.1 and wifi end address might be 192.168.0.4 where as your ipod might have an ip address of 192.168.0.7 ( just an example ) so even though the password is ok, it will let you connect for that few seconds, as it has verified the password and is correct, but the ip handling has not allowed you access and the firewall then steps in and blocks you.... hope this helps
Jan 01, 2011 | Apple Computers & Internet
Samsung Galaxy GT-I9000 keeps trying to obtain ip address from home wifi but does not connect, but at work it connects to work wifi with no problems. Work is using a WEP encryption but my home is using WPA...
  • Go into settings
  • Wi-Fi settings
Nov 25, 2010 | Samsung Galaxy S GTI9000 Smartphone
DNS FAiLED thats only the problem .. i can connect to wifi but when i start typing the url then enter go ..the response is dns failed
Oct 28, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Cell Phones Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
