Question about Zanussi Washing Machines
Blown fuse Our Zanussi ZWG1120M washing machine blows the 15 amp fuse during the cycle. It would appear this happens during the wash cycle but before the rinse starts. The machine is under 3 years old and is only used between 3 and 4 times a eek. What is the likely cause.It is only th use in plug tha blow not th ip sitch. w have put an extnsion lead into another ocker and it sill blows so that would seem to rule out a general electrical fault. Any help or suggestions will be appreciated please
SOURCE: Fuse keeps blowing
This is probably a water heater problem  Try operating on the lowest temp  eg.15C If it goes through the cycle then its more than likely your water heater  You will need a refit
Posted on Jun 15, 2008
ngfam1
  • 639 Answers
SOURCE: Washing machine electrical problem
Dear BIGTREV,
ngfam1 here for you!
I am happy to be of assistance!
STOP!! FIRE HAZARD!
IT IS DESIGNED TO BLOW FUSES AND OR THROW BREAKERS AS NOT TO ALLOW A FIRE TO HAPPEN!
THESE ARE SAFETY FEATURES OF THE 20TH CENTURY!
I believe you should use service for this particular situation!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF
Posted on Aug 26, 2008
grandadfixer
  • 99 Answers
SOURCE: indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Posted on Oct 11, 2008
ltldab
  • 152 Answers
SOURCE: smeg washing machine WM63141BK blowing electrics
SOMETHING IN THE WASHER IS SHORTED TO GROUND
Posted on Feb 26, 2010
  • 2468 Answers
SOURCE: My washing machine is blowing my fuse!!
either the motor start capacitor on the machines motor is shorted,the motor winding itself is grounding itself out to the case and shorting or you may have a bare wire touching the metallic frame in the machine
Posted on May 14, 2010
When using Delicate cycle machine does not drain fully. How can I empty machine before next wash Zanussi Lindo 300
sometimes small items get over the edge of the tub & as you said can plug the pump, most get caught in the hose
Feb 12, 2015 | Zanussi Washing Machines
Zanussi zwf1421
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
Apr 28, 2012 | Zanussi F1245W Front Load Washer
No power to my washing machine (fuse changed still no power)
hello, have you checked the glass fuse inside the power supply if it has blown make you use the same rated fuse if it blows again the you have dead short in the washer somewhere hope it helps
regards
shaun
Jan 03, 2011 | Zanussi FC1200W Front Load Washer
Zanussi ZWD1470W fabric conditioner compartment won't drain
fabric conditioner is dispensed during rinse cycle, if it does not work then either, try pouring hot water into dispenser, as conditioner tends to get goopie when dry, thus may have clogged up
Dec 11, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
Washing machine fuse blows every couple of washes
the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then. it shouldn't since it wasn't blowing everytime on the 15 amp circuit, but never put a 20 amp fuse in a 15 amp socket! the fuse can handle the load[ no pun intended], but the electrical wire would burn not blowing the fuse, thus causing a fire.
hope this helps.
wg
Feb 17, 2008 | Creda W100FW Front Load Washer
Washing machine blown fuses
Hi - had a similar problem with about 3 different makes of washing machine - the RCD switch on the main household fuse box was continually tripping . Nobody could give me a right answer . Eventually ended up with a Hotpoint . Felt sorry for the delivery guys from the electrical retailers having to keep dragging machines in and out .
May 07, 2007 | Indesit WA 115 Front Load Washer
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
assuming you had correct value fuse, fuse blowing may have been caused by a machine fault.after power outage, cycle should resume.
Mar 20, 2007 | Zanussi F1245W Front Load Washer
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
