Question about Toshiba A205-S4577 Notebook
The power light is flashing blue on my Toshiba laptop. It starts to turn on but then shuts down immediately. It does this whether the battery is in it or not. It is hooked up to an external power source. I was told at Best Buy that it should run without the battery installed but have been told different by other sources.
  • Toshiba Master
  • 4,806 Answers
Hi there.
Yes you can run the laptop on AC power only without the battery installed but it sounds to me like its overheating.
Buy a can of compressed air and give short blasts through the air vents and the CPU fan which is located underneath the laptop.
If this does not work the CPU fan may have quit and it will need replacing.
Good luck and thanks for using FixYa!!
Posted on Apr 23, 2009
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
Computer shut down and won't turn on. With power connected, battery light flashes orange 7 times then nothing. Comp won't turn on. Attempted holding power button down for 30 seconds as seen in a forum. ...
If your pc will not turn on immediately it is possible that your laptop is overheating. Try using compressed air and blow out dust and dirt. If it still does not work, you have a faulty cooling system.
Apr 23, 2011 | Toshiba Satellite L305-S5891 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
I have a Toshiba Satelite 1805-s253. When I turn it on, it attempts to start but then will immediately shut down with the power indicator flashing orange. I check the power supply and that is working ok.
power supply must b okay but the lead connecting laptop may have gone faulty, try changing it, if this is not the reason then some internal hardware problem
Sep 12, 2010 | Toshiba Satellite 1805-S253 Notebook
Blinking AC light with/without battery, computer shuts down
I want to try a very simple thing, cause it happened to me, while I am working on my computer , it shut down unexpectedly... cause the processor is working with its full performance and no enough cooling around the laptop. so while I move to other place and also I raise the laptop a little bit from the back to let the fans (bottom of the laptop) works perfectly .
try to open it again and do so.... may be it is a so simple thing that was far from your mind like I was before... good luck
Nov 29, 2008 | Toshiba Satellite A135-S4527 Notebook
Power conflict
Thats an infamous retard sowtware fukup tweak your settings back to default LAPTOP power settings if it no workie then its a connections issue in wich case get it seviced by a pro (not geek squad)....unless your a rich guy with money to burn
Oct 27, 2007 | Toshiba Satellite A135-S2386 Notebook
Toshiba A205-S4577 Notebook Logo
286 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
