Question about HP Officejet Pro 8600 Plus e-All-in-One Wireless Inkjet Printer - $50 Instant Rebate Use Code HP50
Error 345 hp 8600 officejet pro when sending fax
SOURCE: i have a hp officejet
Try unplugging and plugging in again. Many modem failures on this model.
Posted on Aug 31, 2008
leroyal
  • 2120 Answers
SOURCE: Have installed a new HP
It should receive straight out of the box. Is your phone line DSL?
Posted on Sep 01, 2008
leroyal
  • 2120 Answers
SOURCE: cannot receive or send faxes,
Strange...
Try unplugging the machine for 10 seconds, normally HP's will tell you if the have a bad modem ("checking phone line").
Plug a regular phone into the wall jack and listen for a dial tone also make sure the phone cord is plugged into the LINE port of the fax not the phone icon port.
Posted on Oct 02, 2008
  • 111 Answers
SOURCE: FAX errors 345 346 and 350
HP.com has a web page for your product with all of the fax error codes listed and how to interpret them:
Fax Error Codes
Once the page opens, you'll have to scroll down until you find your error codes in the list. The codes in that section of the page don't seem to line up well. All of the codes have to do with the quality of service on the phone line. If the people you're faxing to are receiving all of their faxes except from you, I'd suspect your phone line may have a problem. Here's what I got from the list:
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Check with your phone company to see if their are any problems on your line. It looks like anything that even momentarily interrupts your phone connection will cause these errors. Good luck.
Posted on Nov 04, 2008
SOURCE: feeder tray does not feed during fax
Hp help
Automatic Document Feed (ADF) does not pick up paper. Follow each step, problem seems to be in pick assembly. Prcess took less than 5 minutes with a successful outcome.
Posted on Apr 29, 2009
We are having issues faxing to one particular number. We think our fax goes through, but spits out a Error 345*. Nothing is sent
fax machines talk to each other before sending data to ensure that the sender/receiver are on the same format and are compatible
for one particular number to be a problem indicates a fax number problem in setting the dialed number area code , dashes etc are all specific
ring the receiving department and ask to confirm that they are having trouble receiving faxes from your number as well
Dec 14, 2016 | HP Office Equipment & Supplies
I bought all new cartridges, inserted them the way they were removed, but message board still says defected cartridges. how to install ink properly and make error message disappear?
Here is a video from HP explaining the process. IF you followed this procedure and are getting errors, then you may have bigger issues. I am assuming you are using genuine HP ink, not remanufactured or refilled cartridges.
Replacing Cartridges for HP Officejet Pro 8600 All in One Printer Series...
Aug 31, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
How can I send a fax?
see page 22
you can scan and send as fax
To use more advanced settings of HP Digital fax see pages 52 .. 62
http://h10032.www1.hp.com/ctg/Manual/c03026243.pdf
Apr 12, 2016 | HP Officejet Pro 8600 Plus e-All-in-One...
My HP 8600 Premium no longer sends or accepts FAXes. It says it's connecting, but never does. And returns error 344. I know the other fax machines are working fine. Please advise.
Here's a document that explains some on the fax error codes: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549
The code 344 indicates noise or static on the line and usually the best way to get around that is to disable Error Correction Mode and/or lower the fax speed.
To disable the Error Correction Mode (ECM) touch the right arrow, then Setup, then Advanced Fax Setup, then down arrow and then Error Correction Mode and set it to Off.
To lower the fax speed, also go to Advanced Fax Setup and set it to Slow.
Nov 07, 2014 | HP Officejet Pro 8600 Premium e-All-in-One...
HP Officejet Pro 8600 Plus e-All-in-One Wireless Inkjet Printer - $50 Instant Rebate Use Code HP50 Logo
234 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
