No sound - possible sound card hardware failure
I have an ACER Aspire E650 MMX 1 desktop computer that now has no sound. This occured after the box was moved and the speakers became accidentally disconnected. I suspect that the sound card has been damaged. I have checked that it is not the speakers by swapping them to another PC. I have also checked the Sound and Audio Devices Properties for the "Realtek High Definition Audio Properties" but this says that the device is working properly. The drivers appear to be recently updated. Is there a check that I can do to confirm whether the sound card hardware is damaged ? Appreciate any advice - Many thnx & rgds - Gary
  • Gary Ferguson Apr 23, 2009
    I've never used an on line forum before and am amazed by how quick the helpful suggestions have come through ! Thnx for the advice - I tried headphones in the front panel socket and they worked fine. I then tried again reconnecting the speakers into the rear panel green speaker socket but this time when the Realtek Audio Manager dialog box appeared on screen I ticked a different box to the default - "Line out" instead of "rear speaker out". Now I've got sound again. Problem Solved !! Many thnx to Leecom72 and Techno-Geek for their suggestions.
    Scholar:
  • 38 Answers
Dear GaryFerguson,
The best way you can check the life of your sound hardware is to follow the procedure mentioned below.
Since this may have happened a day or more before: To ensure if the sound card is not having any problem with the Software drivers and is purely hardware failure, Please go through this exercise:
Roll back the setting to earlier time:
Click Start Button,
Then select All programs,
then "accessories",
then, "system tools",
then, "system restore",
A utility will start. click Next.
(Please note that it will not cause any harm to your data so dont worry about it.)
after flipping through couple of screens, it will give you an option to roll back the settings to an earlier time.
Select an earlier Bold date (that means a system check point exists) click on a check point and click next.
It will ask you to restart after reload. Allow that.
(The system will be rolled back to the point you selected (select a checkpoint that was earlier than the problem occured)).
you will see that once the system will restart, it has restored the system settings to an earlier time and your problem is resolved.
If it doesnt not resolve the problem, then you can be sure that the hardware has failed completely and needs replacement. please comment here if you need me for something else.
Have a wonderful day.
Thanks & Best Regards,
Techno-Geek.
Posted on Apr 23, 2009
  • 4,806 Answers
Hi there.
Plug the speaker jack into the green audio port, also check that its not on mute.
To test the card get a pair of earphones and plug it into the pink port and see if you hear the audio.
Post back with the results please.
Good luck and thanks for using FixYa!!
What is the maximum amount of ram can i install in a Acer Aspire E650
if 32x max 4GB. if 64x read your manual or visit manufacturer supportsite.
Apr 06, 2013 | Acer Aspire E650 PC Desktop
On button flashes yellow but wont turn on
unplug the power cable for 10secs. press the power button while its unplug to remove all the electricity in the cpu. connect the power cable and then press the button. if you hear a beeping sound when you turn on the cpu, you have a problem with the motherboard. if no beeping sound, check the 4 diagnostics lights at the back of the cpu, advtrbl5.jpgMemory modules are detected, but a memory failure has occurred.
  • If you have one memory module installed, reinstall it and restart the computer.
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance
advtrbl6.jpgA possible expansion card failure has occurred.
  1. Determine if a conflict exists by removing a card (not the video card) and then restarting the computer.
  2. If the problem persists, reinstall the card that you removed, remove a different card, and then restart the computer.
  3. Repeat this process for each card. If the computer starts normally, troubleshoot the last card removed from the computer for resource conflicts (see "Resolving Software and Hardware Incompatibilities" in the Owner's Manual).
  4. If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance.
advtrbl7.jpgA possible video card failure has occurred
  • If the computer has a video card, remove the card and reinstall it, and restart the computer.
  • If the problem still exists, install a video card that you know works and restart the computer.
  • If the problem persists or the computer has integrated video, see "Contacting Dell" in your Owner's Manual.
advtrb16.jpgOther failure has occurred
  • Ensure that the cables are properly connected from the hard drive, CD drive, and DVD drive to the system board.
  • If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance.
Feb 05, 2011 | Dell Dimension 4600 PC Desktop
XD CARD READER NOT WORKING, NOT RECOGNITION
Try Reinstalling the drivers for the reader. If you go to your my computer Icon right click and go to properties. Then go to the hardware tab and then the device manager. Locate your reader and click on it. In the properties window you can reinstall the driver.
Feb 12, 2010 | Acer Aspire E650 PC Desktop
I need the driver for acer asprire e2200 speakers
Speakers don't use drivers.
It is your sound device. Either it doesn't have the drivers it needs, or it has a hardware failure.
Jun 13, 2009 | Acer Aspire M3641 Dual Core E2200 PC...
Install ATI Radeon X1550 PIC on Acer Aspire E650
If you think the PC boots up but just no screen, check the Graphics settings in BIOS for first/initial diaplay with PCI instead of other Graphics Ports (on board/PCIe/PCI/AGP)? Disable on board display if any.
May 27, 2009 | Acer Aspire E650 PC Desktop
Cable hanging out from above the opticial drive ACER ASPIRE E650
DOES IT COME FROM OPTICAL DRIVE
if yes, and u are using windows xp or later, then no worry
if yes , and u are using windows 98 then u need to plug in mainboard near pci slots
thanks
Apr 10, 2009 | Acer Aspire E650 PC Desktop
E310 diag lights 1 & 2 stay on a long time (10 minutes)
  1. Determine whether a conflict exists by removing a card and restarting the computer.
  3. Repeat this process for each card. If the computer starts normally, troubleshoot the last card removed from the computer for resource conflicts (see "Resolving Software and Hardware Compatibilities" in your computer Owner's Manual).
  4. If the problem persists, contact Dell for technical assistance.
Feb 04, 2009 | Dell Dimension 4600 PC Desktop
Lack of sound
your model number is Aspire T180 and and you don't have any sound output.....
So, i suggest you that please check your sound card by right click on the My Computer and select the properties option then select the hardware option & see you have any sound device or not ... If you have sound device So please insert the Aspire T180 Driver CD into CD-ROM Device & install the Sound Driver & then restart your computer & your problem has solve...
Nov 01, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
