Nec lt150 projector fan noisy - Office Equipment & Supplies
3 Suggested Answers
Mark_Webber
  • 472 Answers
SOURCE: noisy fan
Quite possibly getting past it's used by date.
The other thing to check for is the deaded dust. If the fan is covered in dust, it will not cut cleanly through the air and make noise.
Do not use any cleaning soloutions to get rid if the dust, instead, use an old toothbrush. This will be a little tricky if it's one of the fans underneath, but if you cannot remove the fan to clean it, then have someone hold the projector up, so the hole faces down..and the dust will fall that way as well instead of back into the projector.
Posted on Apr 17, 2008
KingDWS
  • 1606 Answers
SOURCE: My nec Versa E6200 has extremely noisy fan. how to
Fan noises can be caused by wear or dirt. If they are worn the bearings might be gone or going and cause a squeel type of sound. That can only be fixed by replacing the fan. The fans are not expensive but the labout can be.
The usual problem is just caused by dust and dirt built up on the fan blades. The blades get out of balance and then rub or cause noises. If this is left long enough then it can cause bearing damage. If you catch it before then all it needs is a cleaning. You can do this by mechanically stopping the fan so it doesn;t spin and then blwoing compressed air to blow off the dust. The cpu fan and the powersupply fan both with clog up from dust and cause heat problems as well as the noise. Any of these fans are replaceable without buying major parts if needed. ie you don;t have to buy a new power supply, just open the power supply and put a new $5 fan in it. If the computer shop isn;t very good they will force you to buy the power supply instead of fixing the fan.
It's a bit hard to know what the cause is without being able to hear the fan but those are the two ways the fans have problems.
Posted on Jun 14, 2010
NEC WT610 Projector powers up and acts like normal, but will not project an image or the usual blue screen with menu functions. Bulb is fine and lights up, no error lights showing. It's as if it's stuck on...
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Feb 05, 2015 | NEC Office Equipment & Supplies
NEC M420x blinking and no light, can help me /
1,Check the fans ,whether the fan is running,when you turn on the projector
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Dec 10, 2013 | LG RD-JT52 Replacement Lamp
The status light is on our NEC MT850 and the bulb looks fine. What other problems could it be?
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp may be fault,and other parts is working well
Have a nice day!
Jerry
Lampdeng Limited
Nov 19, 2012 | NEC MT850, MT1050, MT1055, MT1056...
Nec VT 670 It overheats after 30 minutes of use. This is when the fan is on auto. Appears to be OK on man full fan speed. The room temperature is OK and the bulb life has 96% left. Any solutions. The...
hi,
Check the lamp cooling fan of your projector one more time. may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Mar 27, 2011 | NEC VT670 LCD Projector
Nec projector is making a high pitch noise from the fan after it heats up
so u can first do oiling in ur fan & put it into some open place
Jan 18, 2010 | NEC VT460 Multimedia Projector
Nec lt20 how to repair "cooling fan not operating"
you'll need to replace the fan. however, nec does not sell parts. you'll need to send it in to them. unless you remove the fan and, using the part number on the fan, search the internet for a replacement. try digikey.
Nov 29, 2009 | NEC LT20 Multimedia Projector
What are the problems with the LT51LP? I have to replace ours about twice a year (costly). Otherwise no problem...
clean out your projector with canned air. the dust keeping in the heat and restricted air flow will shorten the life of the lamps.
Nov 12, 2009 | NEC LT51LP Projector Lamp for LT75Z, LT150
Clean Filter - NEC VT700 projector
Need to go into the menu and find the option to reset. Choose the "reset filter hours" option.---Rick
Sep 04, 2009 | NEC VT700 Projector
Red light blinking in nec lt 260
how many times? that will tell you what's wrong:
1x- lamp cover (close lamp cover)
2x- temperature problem (too hot. clean out and cool down)
3x- power problem (check power)
4x- fan problem (one or more fans not running)
6x- lamp fails to light (lamp or ballast problem)
Sep 02, 2009 | NEC LT 260 Multimedia Projector
NEC VT 440 Projector noise
The unit needs to be opened and have the fan checked. If it is out of warranty and you are capable you should be able to access the fan quite easily. It may be rubbing against something or it may have contaminants inside and needs to be replaced.
Jan 25, 2009 | NEC VT47 Multimedia Projector
44 people viewed this question
jasbo
jasbo
