Question about LG 42LC2D 42 in. LCD HDTV
I have an lg475010 lcd tv the tv has vertical & horizontal lines all over the screen? engineer replaced tbe main pcb board, this only cured the problem for a few hours? any ideas on what the problem might be? would be great?
  • 2,071 Answers
Your problem is a symptom of defected inverter replaced the inverter so its works normal again.
Hope it may help you;
Posted on Apr 23, 2009
Vertical and horizontal lines on samsung plasma tv
Check the Vs and VA voltages to plasma panel. If these voltages, that comes from the main power board is abnormal, this kind of fault can occur. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 19, 2016 | Samsung Televison & Video
Sharp LCD TV takes a long time to turn on
Aug 16, 2016 | Sharp Televison & Video
Sharp LCD TV Takes 20 minutes to warm up
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Aug 12, 2016 | Sharp Televison & Video
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
Lt26hvx olevia has vertical and horizontal lines will new main board p506201 fix
T'Con board fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line faults to all LCD TVs; irrespective of its brand and size, will be similar.
Sep 12, 2015 | Olevia LT26HVX 26 in. LCD Television
Vertical line
Check the deflection yoke connection cable for any loose contact at its connection socket at main board side. Unplug the connector out from the socket, and re-plug it back for at least tow times. Check the solder terminals of all connections to horizontal output. It will be best to re-solder all suspected solder terminals there. [horizontal sweep signals to the deflection yoke is absent now. Only vertical sweep is present now]
Aug 22, 2012 | Toshiba 32A43 32" TV
I also need a 52" samsung lcd panel raplacement i think?
Ur main PCB properly have cracks in the board,the connnections dosen't gose trought smoothly.U need take it a parts,get wires soldiers points to points,glue the PCB all together.
Aug 20, 2009 | LG 42LC2D 42 in. LCD HDTV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Lines on tv screen
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Vertical line at the left of the picture
Replace L506 on A board, replacement part number 1-407-366-00
Nov 26, 2007 | Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
263 people viewed this question
Computer Repairing
Computer Repairing
