Question about Mobile Rack SNT-125 SATA Plastic for serial ATA HDD (without extension front ports) Drive Case
SNT Serial ATA Mobile Rack Removable Frame for 3.5" Drive BlackTray
How to set the JB Jumper Setting on a wd25eurs Harddrive
if its a sata hard drive there are no jumper settings the larger driver should take the job as primary
if you have an ide hard drive
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-1 means Pri slave
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
for the sata
What You Need
  • A Phillips screwdriver and four 6-32 UNC drive mounting screws.
  • A Serial ATA interface cable (sold separately). Maximum length is 39 inches (1 meter).
  • A Serial ATA-compatible power cable or adapter (sold separately).
  • A version of Windows with FAT32 or NTFS file system.
  • A system with a motherboard that has a Serial ATA connector on it, or a Serial ATA host adapter and available PCI slot in which to install the adapter.
Refer to your computer system documentation to see if your system supports Serial ATA on the motherboard and to locate the Serial ATA connector.
If your system does not have a Serial ATA connector on the motherboard, you must purchase a Serial ATA host adapter that is compatible with your computer and operating system and install it with the appropriate device driver according to the host adapter manufacturers installation instructions.
Note: See our list of companies that sell Serial ATA components including host adapters, cables, and power adapters.
Handling Precautions
  • Disk drives are fragile. Do not drop or jar the drive. Handle the drive only by the edges or frame. Keep the drive in the protective anti-static container until you are ready to install it to minimize handling damage.
  • Drive electronics are extremely sensitive to static electricity. While installing the drive, wear a wrist strap and cable connected to ground.
  • Turn off the power to the host system during installation.
  • Do not disassemble the drive. Doing so voids the warranty.
  • Do not apply pressure or attach labels to the circuit board or to the top of the drive.
Attaching Cables and Mounting the Drive
1. Attach one end of the drive interface cable to the Serial ATA interface connector on your computers motherboard or Serial ATA host adapter (see your computer manual for connector locations). Host adapter configuration is shown below.
Note: Serial ATA connectors are keyed to ensure correct orientation.
2. Attach the interface and power cables to the drive.
3. Secure the drive using four 6-32 UNC mounting screws in either the side-mounting or bottom-mounting holes. Insert the screws no more than 0.20 inches (5.08 mm) into the bottom-mounting holes and no more than 0.14 inches (3.55 mm) into the side-mounting holes.
Note: Do not overtighten the screws or use metric screws. This may damage
the drive.
Configuring the BIOS
Close your computer case and restart your computer. Your computer may automatically detect your new drive. If your computer does not automatically detect your new drive, follow the steps below.
1. Restart your computer. While the computer restarts, run the system setup program (sometimes called BIOS or CMOS setup). This is usually done by pressing a special key, such as DELETE, ESC, or F1 or F2 during the startup process.
2. Within the system setup program, instruct the system to auto detect your new drive.
3. Save the settings and exit the setup program. When your computer restarts, it should recognize your new drive. If your system still doesnt recognize your new drive, see the troubleshooting section on the back of this sheet.
Note: Serial ATA is a new interface type.
Some older systems may see the drive and classify it as a SCSI device if you are using a Serial ATA host adapter. This is normal even though this is not a SCSI disc drive. Many systems BIOS will not identify a Serial ATA drive connected to a PCI SATA host adapter.
This is because a PCI SATA Host Adapter has its own BIOS which is used to identify hard drives connected to it which is separate from the BIOS of the computer.
To determine whether or not the SATA Host Adapter is detecting the Serial ATA hard drive, please consult the documentation provided by the Serial ATA Host Adapters manufacturer. This does not affect drive performance or capacity.
hope it helps
Apr 14, 2012 | Western Digital Computers & Internet
I have a HP Asterope Motherboard The Sata HDD or the Sata CD/DVD cannot in not detected in the BIOS and the computer can not boot-up When I use a IDE drive on the Ide port, It works But I have a...
Reasons a sata device might not be recognized in BIOS:
(1)Serial ATA disabled, enter bios and enable SATA.
(2)Serial ATA cable defective
(3)Serial ATA drive defective
(4)Serial ATA cable defective
(5)Serial ATA device not plugged into power.
(6)Serial ATA power adapter defective.
Feb 26, 2011 | Computers & Internet
Its not a problem to begin? I just want to buy 1 rack like for a SATA III 6 gbps Hard Drive. Will it affect the Hard Drive Speed, reducing it to 3gbps? Or is it just a Rack to support the Hard Drive...
As long as the connector and build quality is good, a rack should work fine.
If the connectors are shoddy, or the fit of the connectors isn't good, then you will have speed issues, or even outright failures.
Aug 29, 2010 | Mobile Rack SNT-125 SATA Plastic for...
HOW TO UNLOCK MY LG AX155
You will be able to unlock it here.. http://www.unlocking4free.com/unlock-your-phone They will provide you the free code once when you enter your imei number there. You need to just check your phone model and service provider.
Apr 05, 2010 | Mobile Rack Aluminum LCD Moblile Rack for...
My rewriter is broken drawer ha been snapped off
This is Dell Support>Dell Dimension E520 Desktop PC>Service Manual,
http://support.dell.com/support/edocs/systems/dime520/en/SM_EN/index.htm
I invite you to left-click on - Specifications
Scroll down to the heading - Drives
Available devices - 4 Serial ATA drives - CD/DVD drive.
Serial ATA. Looks kind of confusing, huh?
= SATA
IDE has been changed to PATA.
(Integrated Drive Electronics)
It has been felt that there would be less confusion this way.
PATA = Parallel ATA
SATA = Serial ATA
http://en.wikipedia.org/wiki/Integrated_Drive_Electronics
The Dell Dimension E520 Desktop PC comes with a dual layer DVD burner, and a DVD drive.
(DVD burner will have DVD-R/W or R/RW on the front usually)
You need a SATA DVD R/RW drive.
Myself I use Lite-On optical drives.
Why?
Cheap in price, high in quality. I have one I have been using for over 3 years, with no problems. Price was around $35 US.
Not advertising for Lite-On.
It's a dual layer, DVD combo drive. Burns CD's, and DVD's. Has the HP LightScribe technology. If I use the HP disks for LightScribe, I can make labels for the disks, or burn a label right on the middle of the disk itself.
TIP: Everyone looks for a f-a-s-t burner! The Lite-On I have is Fast. You Do Not want to burn disks in a fast mode.
Better quality of copying, or recording is done at a slower speed.
Should your optical drive not come with burner software, I recommend Infra Recorder.
It's Free, and works Very well.
(I like it better than Nero)
1) Computer unplugged from power
2) Open the computer case side panel (Side panel release latch is on top, at the rear. In the Service Manua,l you can click on Removing and Installing Parts. Scroll down to Removing the Computer Cover)
3) TOUCH the metal frame of the computer case, to relieve your body of Static electricity.
(Your body carries Static. Static will fry out computer hardware components. Computer unplugged from power you are safe. TOUCH the metal frame, your computer is safe)
4) Removing and replacing an optical drive.
In Removing and Replacing Parts, you can scroll down the page for details.
(Approximately half way down. Under the heading Removing the Drive Panel)
I find the instructions 'Less Than'
The Drive Panel is the Front Cover.
The Front Cover has to be removed, in order to remove either optical drive.
This is done by releasing the blue Slide Latch.
The blue plastic slide, on the side of the optical drive bays.
The plastic tabs are depressed, and the blue plastic slide goes towards the rear of the computer.
This allows the optical drive you wish to remove, to slide forward, and out.
I slide the drive I want forward a little, so that I can get my big hands on those cables.
You will have a 7-pin Data cable, and a 15-pin power cable to remove.
Installation is the reverse of these steps.
Jan 11, 2010 | Dell Dimension E520 PC Desktop
Which HDD Supported To Acer4710z Laptop
Acer Aspire 4710 General
  • Built-in Devices Stereo speakers , Wireless LAN antenna
  • Width 13.5 in
  • Depth 9.7 in
  • Height 1.7 in
  • Weight 5.7 lbs
  • Color Black/light gray
  • Localization United States
  • Notebook type Thin-and-light (4-6 lbs.) , Budget
  • Screen type Widescreen
  • Wireless capabilities IEEE 802.11b , IEEE 802.11g
Processor
  • Processor Intel Pentium Dual Core T2080 / 1.73 GHz
  • Multi-Core processor technology Dual-Core
  • Data bus speed 533.0 MHz
Cache Memory
  • Type L2 cache
  • Cache size 1.0 MB
RAM
  • Installed Size 1.0 GB / 4.0 GB (max)
  • Technology DDR2 SDRAM - 667.0 MHz
  • RAM configuration features 2 x 512 MB
Storage Controller
  • Storage controller type Serial ATA
  • Storage Controller / Serial ATA Interface Serial ATA-150
Storage
  • Floppy Drive None
  • Hard Drive 120.0 GB - Serial ATA-150
  • Storage Removable None
  • Hard drive type Portable
May 30, 2009 | Computers & Internet
What 2nd "Slave" hard drive should I buy to match my "Master"?
Any size hard drive should be compatible, but you should get the same connection type and bus speen if possible (ATA/133). If you get one from a different manufacturer, you'll have to install the bios update that comes with it and set the jumper to slave per the instructions that invariably come with any "add-on" hard drive.
Dec 29, 2008 | Mobile Rack - 3.5 Inch Hot-swappable...
Mobile Rack SNT-125 SATA Plastic for serial ATA HDD (without extension front ports) Drive Case Logo
Top Mobile Rack Computers & Internet Experts
David Payne
David Payne
Are you a Mobile Rack Computer and Internet Expert? Answer questions, earn points and help others
