Kenwood heater ew6708k
Won't get hot
3 Suggested Answers
SOURCE: Kenwood oil filled radiator heater - digital
My EW6708K stopped working after a power outage (was not on at the time, just plugged in). I couldn't find any info online. So I used my last option: I took it apart. Two screws on the bottom opens the unit's electronics. Two more screws inside to get tol the circuit board. I was looking for a reset button. There was a tiny white “thing” on the circuit board. I pressed it and reassembled the unit. That did the trick! Simple. Just be neat and put everything back the way it was.
Posted on Jan 25, 2010
SOURCE: Need Instruction Manual, Kenwood Electronic Heater #EW6708K
I have an original Kenwood instruction Manual for the Model
EW6708EK oil filled electronic heater (eng. and spanish)
Posted on Feb 02, 2010
Heater won t blow air
Sounds like either the heater core is plugged or the hot water valve isn't working
Oct 21, 2013 | Toyota Camry Cars & Trucks
Heater does not turn on
If you have a gas hot water heater that won't stay on, check to see if pilot light is out and relight it if it is. If you have an electric hot water heater that won't stay on, then you should have an electrician check the wiring.
if you need an auto tool you can click here: chinasinoy.com
Nov 05, 2012 | 1990 Toyota Corolla
Can someone please tell me which side of the power cord has the larger prong of the polarized plug for Kenwood Electronic Heater #EW6708K
Assuming this involves a USA power system, the larger (usually silver) prong is the "neutral" contact. The smaller (sometimes gold) blade is the "hot" contact. If you are using a 3 wire cord cap, the round or U shaped pin is the "ground". Two wire cord caps should only be used if the equipment (heater) is electrically double insulated. The existing cord will determine which cord cap can be used. It is also important to use the correct ampere rated cord cap.
As for your heater cable, the easiest method is to use an ohm meter to identify the wires. Open a plate or panel on the heater near the cord. The "hot" wire will be connected to a fuse or switch on the heater. Ensure the switch is off or the fuse is pulled (to isolate the wire from other components), then use an ohm meter to test from the "hot" terminal to the other end of the wire (continuity check). The display readout should be very near zero (less than 10 ohms). Repeat the process for the other wire.
Oct 23, 2012 | Dryers
Hi my kenwood dishwasher kdw243a is not releasing the tablet door and not getting hot ?
It sounds as though the heater has failed. I would expect an error code such as e3 to be displayed. It should be possible to test the heater element with a multimeter set on ohms.
Nov 30, 2009 | Kenwood KW85 Air Conditioner
Kenwood oil filled radiator heater - digital controlls - no instructions and I need them - can't get it to work. Thanks - any ideas? model EW6708K
Nov 26, 2009 | Heating & Cooling
Nov 21, 2008 | Heating & Cooling
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
