Sanyo ce27lc6 b
My xbox 360 in pluged in by HDMI but when I turn on the console it changes to DVI what does this mean?
JSPCEXPRESS
  • 178 Answers
SOURCE: HD DVI HDMI problems.
As long as the phono socket is red or white. That represents Audio
Posted on Feb 13, 2008
  • 4102 Answers
SOURCE: Hooking up XBOX 360
Hi have you tried going into the menu option using the telly controll and switching the hd mode on this should then allow you to use the xbox through hdmi cable
Posted on Feb 29, 2008
  • 668 Answers
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Posted on Jun 18, 2009
SOURCE: No sound with HDMI cable and Xbox 360
FROM THE TOSHIBA MENU, (FIRST MAKE SURE YOU ARE SET TO
THE HDMI PORT THAT THE XBOX IS PLUGGED INTO) THEN SELECT
HDMI SETTINGS, UNPLUG HDMI CABLE FROM THE TOSHIBA TV (LCD
FLAT, MINE IS A 42") WAIT FOR THE SETTINGS TO HIGHLIGHT OR NOT
BE GRAYED OUT, THEN TURN OFF THE THREE SETTINGS, FOR COLOR
AND LIP-SYNC., SCROLL DOWN AND PRESS THE RESET BUTTON,
WAIT FOR MESSAGE TO APPEAR. TURN OFF THE TV AND PLUG IN THE XBOX.
TURN EVERY THING BACK ON. SEE IF IT WORKS.
NOT ALL CABLES ARE THE SAME AND NOT ALL TVS ARE THE SAME.
READ THE TV OWNERS MANUAL CAREFULLY, (RTFM), I FOUND A NOTE ABOUT
THESE SETTING ON THE SPECIFICATIONS PAGE.
Posted on Jul 13, 2009
  • 1702 Answers
SOURCE: when i plug an hdmi
Hi, When you use the HDMI you have to switch the TV to HDMI to make it work. Not the other way around. Select the menu on your TV click to HDMI 1 or 2 depending which you are using. Sometime you have to ignor what it says. Try it out any way. Good luck.
Posted on Jul 22, 2011
I have a Sanyo HD flat screen model DS27930 and I'm not sure how to hook up my XBOX 360 to it. ;3;
On most flatscreens there is around four HDMI inputs. Any of these should work. The HDMI should connect from the Xbox to the HDMI input on the TV which is usually on the side of on the back.
Jan 29, 2016 | Microsoft Xbox 360 Console
Xbox360 to pc monitor
HDMI to DVI works better than HDMI to VGA because VGA only uses simple RBG scheme.
Additionally the only way i see the Xbox getting connected to the extrenal speakers is if you get the speakers connected to the monitor/tv or whatever you are using directly. I havent tried or do not know of any way to connect the Xbox to speakers directly.
Dec 17, 2013 | Microsoft Xbox 360 Console
How do I get sound from my Xbox to my monitor via a hdmi lead - DVD lead
As far as I know, the DVI cable can't send sound, so if you could use a only-HDMI cable or SCART cable, that should give you both picture and sound.
Nov 11, 2012 | Microsoft Xbox 360 Console
When i try to play my x box on my sanyo tv no sound comes out of the tv
Try a different HDMI input and a different cable.
DVI is same as HDMI in regards to the picture signal, but lacks the audio.
Apparently for some reason the TV does not pick up audio and that could be because the HDMI port has a problem (say physical contact) or because the cable has a problem or (of course) because the XBOX does not output signal for some reason.
My first two picks would be the port and the cable.
hope this helps!
www.coppelltvrepair.com
Oct 08, 2012 | Sanyo 52" Class LCD 1080p 120Hz HDTV,...
HDMI Problem
ok i think you need to reset the video settings here is a step by step procedure which you can follow
To reset the display settings of the Xbox 360 console to the default settings, follow these steps:
  1. Remove any discs from the disc tray.
  2. Turn off the console.
  3. Turn on the console.
    Note If you are using an Xbox 360 Wireless Controller, turn on the console by using the Xbox Guide button on the controller. Wait for the guide light to indicate that the controller has linked to the console.
    Note Make sure that you use the player 1 controller when you do this. The player 1 controller is indicated by the upper-left quadrant light on the console.
  4. As the console starts, press and hold the Y button as you pull the right trigger.
    Note This action causes the Xbox Dashboard to reset the display settings to the default settings. The console then automatically restarts.
Jul 10, 2009 | Microsoft Xbox 360 Console
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
No sound from my xbox 360
You cant have HDMI and the xomponent cables pluged in at the same time.
to get audio to your monitor you will need an xbox 360 audio adapter. You can find that here. http://www.xbox.com/en-us/hardware/x/xbox360hdmiavcable/default.htm
That comes with the HDMI and audio adapter.
You can probabaly find it seperate somewhere else.
I hope this helps.
Dec 29, 2008 | Microsoft Xbox 360 Console
Try using another setting.
Dec 24, 2007 | Microsoft Xbox 360 Console
XBOX with HDMI
hdmi only works on the premium, older ones don't support it, there you should use scart
Dec 01, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
