Question about Nikon Coolpix 2200 Digital Camera
Zoom is not working when the dial is at the green camera setting.
Camera will not focus
There can be so many issues, but to make sure it has nothing to d with any setting, remove the battery and after you replaced it, set the camera to automatic (green camera logo on the main dial)
then try making a pictures as described in the manual:
position a subject to the middle of the frame, press the shutter release button halfway and wait till the subject in the focus area glows green. (I hope this time it works) then press the shutter complete. If it now works, perhaps it is clear where the camera setting was wrong? Be aware the camera needs a subject with enough contrast and enough light to focus correct.
You also could shoot by taping the part the camera should focus on, on the screen. And because yur camera has so many options to focus, i do advice you to look in the manual and check what modes the camera has. Perhaps in the future you can recognise how or on what the camera want to focus.
I hoop your camera does not have any defect.
success.
Jan 17, 2014 | Nikon Coolpix S4000 Digital Camera
Please help me to use Vivitar 650 - 1300 MM lens
The lens does not have the electronics to communicate with the camera. You must set the camera to the Manual exposure mode (turn the mode dial to M). You set the shutter speed by turning the command dial on the back of the camera. You set the aperture by turning the aperture ring on the lens. You get no exposure help from the camera's exposure meter.
May 27, 2012 | Vivitar 650-1300 Manual Focus T-Mount...
Language option
Selecting the desired language:
1. Set the mode dial to P and press the power to switch to turn on the camera to the ON position.
2. Press MENU button.
3. Press arrows dial buttons to select the MODE MENU.
4. Press arrow dial buttons to SET UP tab.
5. Press arrow dial buttons to select Language.
6. After selecting the language press OK dial button on the middle of the group buttons.
That is all. So you can change the language by this way.
Regards.
Apr 15, 2010 | Olympus Camedia C-755 Ultra Zoom Digital...
Canon Powershot A1000-IS stuck on zoom plus shutter problem.
hello. If there is a reset, it will show it here in the manual. go to this web address. http://gdlp01.c-wss.com/gds/0300001222/PSA1000IS_CUG_EN_02.pdf hope this helps. Ron
Sep 08, 2009 | Canon Powershot A1000IS Digital Camera
Olympus D-545 won't change settings.
Rotate the dial around a few times to refresh the contacts.
May 03, 2009 | Olympus D-545 Zoom Digital Camera
Olympus s P-550UZ,
Turn the camera dial to the letter P on the mode dial. Then go to the Menu and left arrow over to Reset and press Ok. You will see Reset Yes or No. Highlight Yes and press Ok. This will reset the camera to all of its factory default settings. The zoom feature should be working again.
Nov 17, 2008 | Olympus SP-550 UZ Digital Camera
Casio exilim ex z75 zoom problem?
yes the easiest way to fix this is to go in to setup menu and do a reset on your camera once you reset it the digital zoom should come back make sure digital zoom is turned on.
Aug 04, 2008 | Casio Exilim EX-Z750 Digital Camera
I have a lumix DMC-F27 camera it will no longer zoom. No I not in movie mode.
Do you mean DMC-FZ7?
I own one. Assuming that the camera is working normally, then I know two settings that will cause the zoom to be fixed.
Suggestion No. 1:
If the zoom is fixed at the wide end:
1. Turn the mode dial to "P". Now turn on the camera.
2. Press "MENU SET".
3. Press the up arrow button.
4. Now, a menu item named "CONVERSION" should be highlighted. Press the right arrow button.
5. A sub-menu screen should now pop up, select and set "OFF".
Suggestion No. 2:
If the zoom is fixed at the telephoto end:
1. Follow Suggestion No.1.
Suggestion No. 3:
If none of the above solve the problem, then the lens might have been knocked slightly out of position.
~If the camera has been dropped.
~If the camera has been thumped or banged.
~If while zooming, the lens was obstructed.
The zoom motor also could have died, it costs about $50.00 U.S. at Panasonic.com.
My best advice would be to contact panasonic customer service.
Jul 19, 2008 | Cameras
Malfunctioning of Nikon 2100
I had the same problem.The shutter button is faulty and is always half pressed - auto focus is operational (this is the step before actually the picture is taken. Try to clean it up with some special electrical contact spray. if this does not work - need to replace it - Not a simple job for the novice. You might need to take the camera to a service center for a spare on-off-expose button. I had an old faulty camera where I took the button from it. That solved the problem.
Nov 27, 2007 | Nikon Coolpix 2100 Digital Camera
Nikon Coolpix 2200 Digital Camera Logo
16 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
