Question about Siemens Lands Phones
Siemens realitis dt60
Store numbers
Timing adj. 1983 dt60 suzuki outboard motor
timing is fixed by the flywheel .
Aug 04, 2016 | Boating
I have a Siemens Hipath 3550, extension have dial tone but when making internal calls the receiver cant hear me (caller). Can someone help me please.
calm down. Breathe deeply and get a grip on reality. Someplace is customer support. If not, you've been grubred.
Nov 26, 2014 | Siemens Lands Phones
What are the circuit breaker part numbers for a Siemens Ite G3030MB1200 Panel
Go to any home store and ask them, they will have the breaker or one to use as a replacement
Sep 04, 2014 | Siemens Electrical Supplies
1985 suzuki dt60 diagram
did you remove the pin below the carbs for the gear rod ?
Jun 02, 2014 | Light Outboard Motor Boat Bass Fishing...
How do I store numbers on the phone
type the number on the screen & go to the option menu and save it,,,,,,,,,,,
Oct 14, 2010 | Siemens Euroset 2015 Corded Phone
Need head unit pin outs for VRCD500 - sdu as am in uk and can't buy harness
hello , i'm looking for a manul and wiring harmed for car radio virtual reality sound labs model number vrcd500-sdu
Jul 09, 2010 | Virtual Reality Sound VR3 CD Player w/ USB...
Need to know year of this outboard
Go to the Search, type in suzuki dt60, there will be many items to help. Its between a 1977 and 1984. Some of your numbers are serial #s and you can probably use the #6001 or the second number to be more exact.
Apr 30, 2009 | Boating
Radio stations
tune in to station you like hold down button 1 till it beeps or flashes the beep or flashes lets you know its stored change the tuner and press button 1 on unit and it should go to the station you just programed (do same steps for all other button numbers.
hope i helped
Feb 28, 2009 | Virtual Reality Sound VR3 CD Player w/ USB...
Programmed speed dial - internal calls
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
Jan 19, 2009 | Siemens optiPoint 500 Standard Corded...
To store phone numbers in Memory
I found it out eventually ...
Assholes make this site free for everyone ... Spread Humanity instead of making loads of money.******* Capitalists
Jun 16, 2008 | Siemens Euroset 2005 Corded Phone
Lands Phones Logo
51 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
