Question about Akai Televison & Video
My Akai dvd player model no:DV5051AK doesn't read usb device.
SOURCE: MUTIZONE INSTRUCTIONS FOR AKAI DVD PLAYER DV-P3570DS
Try Hi-Fi Corporation or where you originally bought your DVD, they can unlock it for you. I have the same and I DVD never had problems with playing imported DVDs from the US.
Posted on Mar 27, 2009
stonephoenix
  • 563 Answers
SOURCE: hi, our AKAI DVD player is not reading... wat to
When a dvd player stops reading disks, there are only two possibilities.
1. The lens inside the player needs to be cleaned with a disk cleaner.
2. Something has gone wrong with the dvd mechanism resulting in the need for repair.
You will not be able to get that particular unit repaired because Akai no longer has the parts available to fix it. If lens cleaner doesn't work, it's time to purchase a new dvd player.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 02, 2009
caroldon
  • 17129 Answers
SOURCE: Why doesn't my DVD player read DVDs ?
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Posted on Aug 22, 2011
  • 347 Answers
SOURCE: What's your problem?my portable lg dvd player not read any movie when i use usb port . how can i play the movie in portable dvd player using usb port
refer to user manual for detailed info
Posted on Nov 13, 2011
  • 6771 Answers
SOURCE: sony dvd player doesn't read disc says no disc when loaded
This would indicate the laser pickup assembly is the problem, try a DVD cleaning kit and follow instructions, if no change, far cheaper to replace the stereo.
Posted on Mar 17, 2012
Why can't my Panasonic DVD recorder read my portable harddrive? I want the DVD record to read the harddrive?
hi anonymous, it may well be that you need to change settings on your DVD Recorder and/or on your TV. On my LG 42" TV I need to select the input mode ie. Movie, USB, music etc, as necessary. Maybe your DVD Recorder or TV can't handle the file format on you Portable Drive, check the manufacturer specs.
Jun 08, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hi, I have a Samsung DVD Player H1080 R. Nice player with sleek design. When I try to connect my Seagate Go Flex USB 2.0 Plug & Play (1 TB), it doesnt play. There is data in the external hard disk,...
Good day!
These are the 2 possible causes and solution on that problem:
  • The format of the file on U.S.B device is not compatible to the format requirements of the DVD player.For example your DVD player required A.V.I or MPG/M-PEG for the video while the file format of your U.S.B is F.L.V and when you try to insert it to the U.S.B port the file doesn't read.You have to do is convert the file that store on your U.S.B device depends on the format requirement of your DVD.Use a total video converter to convert the file on your U.S.B to the format you need to play on the DVD player.
  • Or the problem could be the U.S.B itself,because the U.S.B host on this product does not supported all U.S.B device.Please try to use other mass media device such as memory card or mp3 players.
I hope this solution will be helpful.Thank you.
May 02, 2011 | Samsung DVD-H1080R DVD Player
My AKAI tv/dvd combo - DVD quit working.
Most times it's video read issue such as a dirty lens on the laser.If you smoke in the house or use a fireplace there is a lot of airborn stuff to leave a slight haze on the lens making reading the disk impossible.Try a standard cd or dvd lens cleaner.The on that looks like a cd and uses alcohol on one of the cleaning brushes on the disk you've got a 50 50 chance.
good luck
Rich
Jun 06, 2010 | Akai LCT2721AD 27 in. LCD Television
I have a BD-HP16 Sharp Aquous Pure Mode DVD
Cannot operate could be the disc itself (defective) or the DVD drive (defective in need of repair or replacement) itself. However this is how to complete the update in detail.
The update file can be found here http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Select bluray disc players
model not listed
type in model number
Then click on search
Click on the instructions and read thme if you need to. If you do not need to read the instructions click on the firmware and save it to your desktop. After the download has completed open the folder and click on extract all files under folder tasks, which should be on the left of the window nearer to the top.
At this time insert a 1, 2 or 4 GB flash drive into your computer. Then in the window click on next if you need to or browse and then my computer and then the icon of the usb device itself. Click on extract or next. When it is done safely remove the usb device from your computer by clicking on safely remove hardware located near the time on the bottom right hand side of the computer monitor.
Click on the usb device and click on stop. Remove it from the computer and place it in the back of the bluray player. Turn the tv and bluray player on as if you were going to view a bluray. There shouldn't be any discs inside. Press the setup button on the bluray remote control. Choose settings. Choose software update. Begin the update. After it is completed turn off the bluray player before removing the usb device.
If the usb device needs to be reformatted or if the zip file folder is placed on the usb device instead of the extracted file the download will not be successful.
May 09, 2010 | Sharp AQUOS Blu-ray Disc Player
How to change default wallpaper in Akai DVD rw125?
aparece un signo en la pantalla parte inferior derecha de mi televisor, todo el tiempo de reproduccion de material, ya sea de dvd o usb, por favor ayudenme
Jul 29, 2009 | Akai DVDRW120 DVD Recorder
Portable dvd player will not play dvds
I cleaned the eye of the dvd player that reads the dvd's
Jul 17, 2009 | Akai Televison & Video
Akai dvd/vhs/tv combo
Try and get a Lens Cleaning disc and put it into the DVD Player side and wait until it's done.
Jan 05, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Manual lost
akai phone # use to be 310-664-8060
Apr 28, 2007 | Akai DVDRW120 DVD Recorder
Televison & Video Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
