Philips mcm277/12 micro hifi system won't read cds says no disc
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: micro system will not recognise cds
When that happens, often that means you have a lens problem.
Use a dvd lens cleaner kit , like the ones that you see clicking here.
If that does not work, you will need to take apart the unit, access the lens pickup, and clean the lens directly, using isopropyl alcohol and a cotton sticks.
Posted on Oct 11, 2008
AREA51S4B
  • 30 Answers
SOURCE: sony system not reading discs
if cleaning does not work, then you need to replace the laser, this not hard to due if you have some technical
Posted on Jul 27, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a Marantz dr
CD-R's must be made for and imprinted with the words "digital audio". Blank DATA discs will not be used. Do you have the manual?
http://www.retrevo.com/support/Marantz-DR6000-manual/id/511bh840/t/2/
Posted on Jul 16, 2011
Philips micro hifi system mc230 cd door will not open
Could be that the door drive belt (if it uses one) has come off.
Feb 25, 2016 | Philips Audio Players & Recorders
Hi i have technics Compact 5 Disc Cd Changer SL-EH790
Carousel-type changers such as yours are prone to eventual failure.
Mar 23, 2014 | Technics Audio Players & Recorders
I have a Philips Micro System DCM 292/05 Serial no AQ1F1049017669 purchased 28.3.11. The CD will not play displays Reading then displays Err Disc top left displays a pic of a disc &DBB I have...
The laser's reflected signal is no longer detected. All you can do is to clean the unit with a lens disk like
http://www.amazon.co.uk/Hama-DVD-Laser-Cleaning-Disc/dp/B00005UPDF
If this fails then the laser diode has failed and the optical unit is dead - it will have to be replaced.
Jun 13, 2011 | Philips Audio Players & Recorders
HTS6500/37 will not read DVD' s led screen reads no disc, however system will play CD's
If it plays CDs but not DVDs then the Laser is failing and just a matter of time before it stops playing CDs also.
Apr 27, 2011 | Philips Audio Players & Recorders
Hi! I have a problem for reading CDs with an aiwa hifi system
the spindle motor goes bad a lot on these aiwa cd unit
May 12, 2010 | Aiwa NSX-DS55 CD Shelf System
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
MCD196 does not read DVDs anymore, but still read CDs.
change the motor disc spindle loses some velocity thats why dont read the dvd´s
Aug 23, 2009 | Philips DVD Micro Theatre Shelf System...
Sony system not reading discs
Jul 18, 2009 | Sony Audio Players & Recorders
Mp3 not playing thru phillips micro - mcm239d
Philips hifi systems only support flash memory sticks or MP3 players which show up as flash memory sticks.
SA5125 is not compatible
Feb 17, 2008 | Philips SA5125/37 MP3 Player
DVDs & CDs will not play
If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work.
If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches!
Joe
Jan 07, 2007 | Philips DVD Micro Theater Shelf System...
98 people viewed this question
 Grubhead
Grubhead
