Ewf1282 starts wash cycle for 2 minutes then stops.
  • 641 Answers
SOURCE: Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Posted on Aug 07, 2007
  • 22 Answers
SOURCE: My washing machine stops mid cycle
issue where washer stops and water won't drain might mean something is in drain area.
look at my issue "eco smart won't drain, smells hot" and see about the sock. I found one of my husband's socks so far down in the tub bottom that I couldn't see it when I looked between plastic outer liner and wash tub. Had to remove black motor/white housing on bottom of machine--which i had to replace cause it burned out. That is when I saw the sock and pulled it out through a quarter-sized hole.
Posted on Oct 21, 2008
rylee_smith
  • 8619 Answers
SOURCE: stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 29, 2009
  • 530 Answers
SOURCE: Maytag Fronload Washer Error Code FH
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem. Always first check your hoses if you have flood hoses get rid of them next get a bucket and see if water is comeing out of the hoses next check you inlet valve screens see if there is sand in them if there is clean them.
Posted on Jun 23, 2009
ghost4548
  • 776 Answers
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Posted on Jun 30, 2009
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Why dosen't Beko WMB 61631s washing machine work?
    sounds like a software problem.
    Try unplugging for 2 hours, then replugging and starting the cycle.
    The long unplug is to drain memory voltage.
    Aug 19, 2014 | Beko Washing Machines
    I am after a picture of the motor wiring on an ewf1282 front load Electrolux washing machine. There is a spare yellow wire which comes from the ECU, but the only place it looks like it will attach to
    Good Morning Friend,
    I understand that you are looking for a picture of the motor wiring for your Electrolux washer, model# EWF1282. This appears to be an Australian Electrolux dishwasher. I suggest contacting the manufacturer directly. They might be able to get you a picture of the motor wiring. Hope this is helpful.
    -Best Regards-
    WP
    May 16, 2014 | Electrolux Washing Machines
    Electrolux washer playing up!
    Remove the top panel, there should only be 2 or 3 screws on the back of the panel, then slide the top panel back about 1/4 inch and it should lift off. Look to see if the belt has come off. Post your results back.
    Jun 28, 2013 | Washing Machines
    Washing Machines Logo
    Top Washing Machines Experts
