I have a Kelvinator KSE88HRB air conditioner and I want to remove the cover in order for me to clean the filter inside.
  • 105 Answers
SOURCE: air conditioner freezing up
Your unit is low on freon. Take the unit to a service facility & have it recharged & the leak repaired. Note that ice formation may normal if the outside temperature is below 45-50F. If you must use it in the meantime, leaving the unit on fan only will melt the ice much faster.
Posted on Jul 17, 2007
bobotfel
  • 236 Answers
SOURCE: Leaking Air Conditioner
Try also to check if your evaporator fins is clean cause even if your air filter is clean will still present with dirty fins.
Posted on Feb 20, 2008
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
  • 3 Answers
SOURCE: KELVINATOR AIR CONDITIONER
whats the furnace doing exactly is the filter clean ? does the blower come on if you just put fan on ? do you have pwer to the unit ?
Posted on May 30, 2008
SOURCE: Air conditioner leaks/drips from filter inside travel trailer
Either your 14"x14" a/c gasket is lose on the roof allowing the condensation to flow into your RV or you have a cracked condensation tray under the evaporator. I'm guessing the later
JGRV
Posted on Aug 14, 2008
Kelvinator split system heater off every 5 minutes for about 4 minutes then it comes back on and does this constantly .
Here is the free help link.
Air Conditioner Repair Help
Here is the PDF. It does not list the problem you identify but lists the contact information for Kelvinator. Bear in mind your problem could be a blockage, a bad sensor, or oddly enough, the filter needing changing. This calls for a service technician.
https://theelectricdiscounter.blob.core.windows.net/images/air-conditioner/air-conditioner/kelvinator/pictures/e_series_inverter.pdf
Jun 05, 2017 | Heating & Cooling
Kelvinator split system when set on auto mode keeps heating wells past set temperature
Check your filters... if they are dirty or blocked the set point temperature will be all over the place. If the filters are clean, there may be a problem with the air sensor which is attached to the evaporator on the front of the indoor unit behind the filters. Check and make sure this isnt covered with dust etc. The air sensor usually appears as a black wire mounted on a plastic mount, stuck on the coil ( Aluminium tube part) of the indoor unit behind the filters.
Jul 14, 2011 | Heating & Cooling
How can i remove the fan barrel from the head unit to clean it
with care. first remove the screws holding the covers, you will find them behind two or three small caps near the louvers and maybe under the filter cover. Completely remove the plastic face. Remove the screws holding the coil in place. You can only remove the left hand end as the right hand is connected to the pipework. remove the grub screw holding the fan barrel onto the motor shaft. Remove the screws holding the left hand bearing in place. At this point you should be able to withdraw the fan barrel. Take very real care how you handle the coil, for if you kink the pipes your machine will no longer perform without some major surgery. While the unit is dismantled , try cleaning inside the machine, removing dust and mould. Reassemble in reverse order
Mar 05, 2011 | Fujitsu 12C1 Air Conditioner
I have condensation dripping off the inside case of my domectic caravan air conditioner
Clean the air filter and blow the fins off to stop this problem dirt will cause it to draw water so pull the cover blow out the air cleaner and blow out the coils inside andon the roof this shoud take care of your problems. IF it does not clear up try cleaning the drain hole in the top of the unit by removing the outter cover and make sure the drain tube isclean.
Mar 10, 2010 | Dometic Rooftop RV Air Conditioner
Power led flashing on air conditioner
This generally indicates a fault with the unit. Have you tried cleaning the air filters inside the indoor unit. This may help. Otherwise call Kelvinator or LG as they have similar unit and ask for their help and if it can't be rectified call for service.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
Need to access inside of Carrier air conditioner.
After removing the cover and filter, you should be able to see the fins for cleaning. If there is styrofoam in front of the coil, it should not be there for proper operation.
Aug 20, 2009 | Carrier 52FE312-3 Air Conditioner
How do I remove the front cover of a Fedders 5200 BTU room air conditioner? I need to clean just inside the front cover as it is full of dirt.
In order to do this, you need to have your air conditioner turned off, and then simply pull the tabs on the filter in an upward direction, and the screen type of filter just slides right out. You can wash the filter under hot soapy water, rinse and then just shake it dry. Replace the filter and turn your air conditioner on for a few minutes, and it's all dry.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 10, 2009 | Heating & Cooling
I have a Dometic rooftop air conditioner 8000 model. When on heat in cold climate I found the a/c unit did not heat our caravan sufficiently.
the reason for this is either the reverser valve or air restriction first clean the a/c by removeing the cover on the roof and the inside clean the cooling fins then remove the sheet metal or plastic cover over the intake fan & clean the shroud then clean the filters inside the van reassemble every thing then turn the unit on & from inside check the side were the wires are to feel for air by turning the unit on cool there should be a big diffrance between the intake from the out put use duct tape to seal off the sides also clean the duct work with air to remove blockage in the duct
Jun 05, 2009 | Dometic Rooftop RV Air Conditioner
May 30, 2008 | Heating & Cooling
Loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Dec 27, 2007 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
