Question about Apple Power Mac G5 Desktop
PM G5 has red light at front before switching on
I have a 2GHz PMG5 with 1GB RAM. It is not starting up. When I connect power to it, a red and orange light come on at the front. When I switch on, more lights come up but there is no start up gong and no display. The fans kick in but that's all. Yesterday after a while the fans began to run faster, making more noise than before so I switched the computer off by pulling out at the plug.
I remember reading somewhere before and someone said it is a logic board problem. Is this so? Please advise so that I order a new motherboard if that's what I need to replace.
You should take your Mac problems to the Apple Discussion board - http://discussions.apple.com/forum.jspa?forumID=596 - There's tons of very helpful information there from very experienced users.
Posted on Jun 10, 2009
    Problem Solver:
  • 9 Answers
It could be your motherboard but I would first try a Apple hardware disk and run the diagnostic tests.  If you can't boot from the DVD you could try a PRAM reset.  I have seen other weird issues with the hard drive not mounting which causes the fans to run loud.  The Apple Diagnostic disk comes in your original software pack and its usually on the 2nd or 3 DVD.  Sometimes the CPU speeds get out of whack and they need to be recalbrated.
Posted on May 02, 2009
Whats the color codes for a 2001 dodge ram 1500 stereo wiring harness?
2001 Dodge Ram 1500 Radio Wire Colors
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Mar 30, 2016 | Dodge Cars & Trucks
G5 keeps powering up for a few mins then switches off?
Thank you for contacting Fixya Support, I am glad to assist.
There are a few steps you can try to troubleshoot this issue:
Try a PMU Reset:
* Turn of your iMac if it is already turned off
* Disconnect all connections to the iMac except the power cord
* Now disconnect the power cord for approximately 20 seconds
* Reconnect just the power cable the keyboard, mouse and power cord, and then power your iMac G5 up.
* Check to see if the iMac boots up normally without power interruption.
* If the iMac G5 shuts off again, try these steps, another recommendation would be to remove all connections including the power cord, and lay the iMac G5 on soft cloth face down and with a philips screwdriver, remove the plate on the bottom of the iMac G5 where your RAM memory is located.
Before removing the RAM however, touch your hand on the metal boot to discharge any static current you carry for approximately 5 seconds.
Now remove each RAM card and then reseat (re-install) each card.
Restore the RAM card cover with your Philips screwdriver, reconnect your power cable, keyboard an
d mouse and turn on your iMac G5.
See if this second procedure helps if the first procedure does not work.
Let me know if this helps.
Regards
-Mactechtrainer
Sep 11, 2010 | Apple iMac G5 Desktop
I have a 2001 dodge ram, when I connect either the ground wire, power wire, or both from the cd player I am installing, all of the dash gauges quit working.
make sure your not connecting the power wire to the power for the gauges here is the wiring diagram
2001 Dodge Ram 2500 Truck Car Stereo Wiring Schematic
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
pls rate
Aug 16, 2010 | Car Audio & Video
How can I do a overclock?
You can use the program from this site:
http://thomas.perrier.name/index.html
May 08, 2010 | Apple ATI RADEON 9600 XT for Macintosh G5...
I have HP ProLiant DL360 G5 Server i found
For Server-HP Proliant , Boot using SmartStart Cd(if you don't have download iso image from HP support site--Free & burn it to media)
Now boot using this Smartstart cd and choose Maintain Server...Use Diagostic options..to check hardware.....Also check Drives status....if amber light
Replace hardware or it is Contact HP for any hardware issue
Oct 05, 2009 | HP Smart Buy HP ProLiant DL360 G5 (2x)...
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
HORN DIAGRAM FOR A DODGE RAM 1500 (CONNECTIONS)
Battery Constant 12v+ Positive Wire (+): Black/Orange And Red/White
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Yellow
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Blue (16 Gauge)
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Yellow/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue (10 Gauge)
Accessory Positive Wire Location: Ignition Switch Harness
Second Accessory Positive Wire (+): Orange
Second Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Black/Yellow
Parking Light Positive Wire Location: At Headlight Switch
Power Door Lock Positive Wire (+): Orange/Violet
Power Door Lock Positive Wire Location: In Drivers Kick Panel, White 6-Pin
Power Door Unlock Positive Wire (+): Pink/Violet
Power Door Unlock Positive Wire Location: In Drivers Kick Panel, White 12-Pin
Door Trigger Negative Wire (-): Yellow
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Black/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Gray
Tachometer Wire Negative Wire Location: At PCM, Connector 1, Pin A7. The PCM (powertrain control module) is located on the firewall next to the wiper motor.
Brake Light Positive Wire (+): White/Tan
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Black/Orange (To disarm requires a (-) negative through a 1565 ohm resistor and an extra relay to connect.)
Factory Alarm Disarm Wire Location: In Drivers Kick Panel, White 12 Pin Plug
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Aug 22, 2009 | 1998 Dodge Ram 3500 2WD
I need an audio wiring schematic for a 1997 dodge laramie 1500 4x4 truck.
Constant 12V+ Red
Switched 12V+ Red/White
Ground n/a
Illumination n/a
Dimmer Orange/White
Antenna Trigger Yellow
Antenna Right Front
Front Speakers 6" x 9" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 5 1/4" Side Panels
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 26, 2009 | 1997 Dodge Ram
G5 failing to startup
Two things.  1. Boot from the original install disk and choose your language. Don't install the software, look up to the menu and find disk utility. You will run disk utility on your mac from the CD. You boot to the CD by holding down the "C" button during startup.
2. If you had the insight to set up an emergency user, see if the problem occurs on both users. Sounds like it happens right off, so I think solution 1 is best. Once you get things running, set up another user. I call the account Emergency and use Emergency as the password. This is used for, you guessed it, emergencies. What this does is isolate the problem to the user or the computer.
Apple has a great knowledge base to search for solutions as well. Good luck.
Apr 20, 2009 | Apple Power Mac G5
Power PC G5 Dual 2.5 sudden shutdown and no reboot
In G5 always the cover should be closed properly if not it will start the fan very fast like a blower and the red leds will be on showing that the heat is over so please check that the cover is closed and locked from behind so itworks smooth and the power supply is standard or normal
u should always use genune parts with mac..
thanks
Dec 19, 2008 | Apple Power Mac G5 Desktop
Apple Power Mac G5 Desktop Logo
1,655 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
