Question about Krups Super Automatic XP 9000 Espresso Machine
Xp 9000 has just developed a fault stating that the beans need filling up, however, the unit is full? I have tried all the usual stuff, like emptying the beans out and refilling but nothing?
  • Krups Master
  • 1,317 Answers
It's pretty hard to diagnose without you also reporting what it is doing. Is the grinder grinding or not grinding? screaming_skull@hotmail.com
Posted on Oct 19, 2013
Fridgedair Stackable washer /dryer...fill water cycle does not shut off.
The fill level sensor has probably failed. If you open it up, you should be able to find the sensor. There will be two of these (full and empty)- they are usually disk like object ~ 2 inches in diameter, with a rubber tube coming from the centre. I would try swopping them over. If the fault moves from 'not stopping filling' to 'not trying to empty' (or similar change) you have found the fault. Buy a replacement from an on-line spares supplier.
Apr 07, 2016 | Washing Machines
Why won't it brew?
Think the grinding mechanism is jammed with something. Disassemble unit and look for same.
Sep 03, 2017 | Saeco Vienna Plus Black Super-Automatic
Xp9000 does not in form me that it has run out of beans, any help please , thanks
They only know that the beans is empty when it comes to compressing the grounds into a puck just before brewing. If the brew unit has nothing in the chamber to compress then it assumes you are out of beans.. Remove and thoroughly clean the brew unit and make sure grounds are exiting the grinder when the grinder is running.
Oct 19, 2014 | Krups Super Automatic XP 9000 Espresso...
Problem I had is kept asking me to fill the bean container when is already full? keep finding unused grounds that have fallen behind the grounds tray.
Try to power cycle the unit to clear the bean warning, unplug it and let it set ten minuts to clear the memory. As far as the grounds, make sure your not overfilling the unit and all the bean cup and grounds trays are inserted correctly. you might have to tip it and clean any trapped grounds out of the tray area to make sure the tray seats correctly.
Dec 30, 2011 | Krups Super Automatic XP 9000 Espresso...
Ground coffee will not dispense
The beans are hanging up in the hopper and not falling down into the grinder...... wiggle it, give the beans a push, or go to a bean that is not so sticky....
May 29, 2010 | Gaggia Titanium Espresso Machine
Spidem Trevi Plus coffee is not being dispensed.
The grind chamber is blocked, remove the beans and brew unit then clean the grinds chamber, then adjust the grind 2 numbers coarser and try again.
Nov 05, 2009 | Spidem Trevi Digital Coffee Maker,...
Fuel guage not working correctly
your gauge is part of the integrated unit in the fuel pump module
Sep 12, 2009 | 2005 Chevrolet Malibu
Code E020 on a NP 4050
How about this, Take the developing unit out and take the ATDC sensor out and plug the hole up in the developing unit. Reinstall the developing unit and cheat the front door switch and plug the sensor back in and hold it in your hand and make a copy. Dose it vibrate? If it dose not the sensor is bad... If you really get tired of working on the problem and you don't go to the copier to often and they are not billable, try this.... Take the top cover of the dev. unit and spoon toner into the dev. unit till it is almost full and reinstall it and clear the error code in service mode and just remember to add toner in to it every so often.
Jul 13, 2008 | Canon NP 6050 Copier
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Krups Super Automatic XP 9000 Espresso Machine Logo
117 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
