Question about Car Audio & Video
FORTUNER 2013 A/T DOSENT ALLOW DVD TO PLAY WHILE RUNNING CAN I OVERRIDE IT OR HOW TO PLAY IT FIXIN IT
I REPLACE THE FUEL FILTER IN TOYOTA FORTUNER D4D.BUT THE INDICATOR IS ON LIGHT.HOW CAN I ERASE THE LIGHT
Replacing the diesel filter - Engines - Fortuner 4x4 Fans
www.fortuner4x4fans.co.za/...fortuner/.../382-replacing-the-diesel-filter/
May 15, 2013 - 12 posts - ‎8 authors Car: Fortuner 3.0 D4D 4X4 2010 ... It would also be great to have the knowledge if you need to replace it in the bundu. ... Unplug the top connector on the fuel filter ... Toyotacharged me over R400 labour to do a 5 min job! .... doesnt create an air lock or vacuum of some sort- its free but you have to ask for it. Low fuel warning light - Fuel
May 31, 2014
ABS problems - Electrics
Feb 26, 2014
Low Fuel light on permanently - Electrics
Sep 26, 2013
D4D Fuel FIlter issues. - Others
Jan 1, 2013
More results from www.fortuner4x4fans.co.za
Nov 23, 2015 | 2006 Toyota Fortuner 3,0
I have a toyota hilux with a factory fitted dvd player and when you play a dvd as soon as you drive off the sound plays but you cant see the movie is there a way to change that so it plays all the time
Assuming it is an in dash model, by law it must shut off video if the car is moving, there are alternate outputs on the unit for extra monitors for rear passengers that stay eneabled.
Jan 07, 2014 | Passlock Override PLJX Passlock Override
Headlight globes fortuner 2013
new 2013 model fortuner plz some1 tell me the fog lamp and high beam size of the bulb
Jul 12, 2013 | Cars & Trucks
I have an apex tv dvd combo. the parental controls are blocking the dvd from playing how do I unblock it?
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Jun 01, 2012 | Apex Digital Televison & Video
Cannot play need an compatible dvd decoder
Hi, I think I can Help you today with this.
Most dvd players require decoder software in order for them to work but fortunately, there are several free programs out there that will work for you in this matter.
I recommend VLC, as it is a free program that not only will allow you to play the dvd, but has features for video, audio and sync control as well.
If you don't like that program, you can also try Real Player, Or Divx plus.
Both of these programs are free, and they have the proper dvd decoder software in them as well.
Also, if you can download a program called k-lie codec pack, it may very well fix your problem, without havung to get any of the other software, and you can then play your dvd's using Windows Media Player
I hope this helps you out.
Jan 25, 2011 | Computers & Internet
My onkyo DV BD-507 only play dvd disc, and dosent play blu-ray disc
Sep 25, 2010 | Onkyo DV-BD507 Blu-ray Disc Player, Black
Some DVD's have a disk error "cannot read, disk error" then it ejects. This has only happened on 2 titles....3 of one title and 2 off another title. We have over 150 DVD's in our library and they all play...
Its a possibility that the dvds may be set to a different regional setting that the dvd player dosent read, if there is a setting on the dvd player that allows you change the regional settings try another, the main 3 are pal1,pal2 and ntsc. hope this helps
Sep 23, 2010 | GoVideo Go Video DVD/VCR Combo
DVD player stuck on region 1
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free
www.dvdidle.com/dvd-region-free.htm
Oct 28, 2009 | Acer Aspire 3000 Notebook
I have the avn2454 and it will not play a dvd
is the car in park? There is a manual override that must be done, as it is against the law to have video playing in the driver's view.
Put car in park and apply parking brake. Retry.
Dec 27, 2008 | Eclipse AVN5500 Car DVD Player
Philips DVD Player model DVD622/37 wont play movies
Unplug/replug unit, try commercial dvd's again. If fails - call Philips- find out about replacement options
Jun 29, 2008 | Philips DVD 622 DVD Player
Car Audio & Video Logo
75 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
