Question about Bosch Vision 300 Series WFVC3300UC
Error 13 on Bosch. Door wont open. Clothes inside machine
  • 10 Answers
SOURCE: My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Posted on Nov 27, 2009
SOURCE: Bosch Nexxt Essence Washer
i have the same problem with a bosch at a rental unit i just moved into. the door is locked up until the 25 or 41 minute cycle depending on the cycle used.
$500 to fix the motor, YIKES! and its my responsibility, yikes again.
definitely a motor problem not a door problem.
Posted on Apr 09, 2010
  • 1382 Answers
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
Posted on May 19, 2010
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Posted on Sep 21, 2010
Macmarkus
  • 2605 Answers
SOURCE: The most apparent problem is that my Bosch 500
Welcome to FixYa.
I can't believe the person you spoke to didn't give you more info, specifically the most common problem when dealing with the "E13" error. I do believe you, I'm just embarrassed as a member of this industry with the service at times.
Just proves my suspicion those call centers are nothing more than an answering service with generic "trouble-shooting tips" on a computer screen...not technicians. Fortunately I am an authorized Bosch technician and should be able to get you going. The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
Anyway, here`s the most likely way to remedy a E13 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
( you should also see a ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.macmarkus_28.jpg
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Nov 11, 2010
What does E1 error mean
The Bosch E1 error code indicates the door is not completely closed. This maybe due to something holding the door open, such as clothes trapped in the door, or the latch may not be holding the door securely.
Feb 18, 2015 | Bosch Washing Machines
Bosch error E23 flashing
disconnect the power the door unlock within 30 secound
Oct 12, 2014 | Bosch Washing Machines
My ashing machine is stil under garntee and door does not open
If the door is not opening this could be because it has not drained fully, check the pump filter. Some of the Bosch machines will only open if the dial is in a cycle position ( ie not in the OFF position) If you still have a problem call for engineer on 0844 872 8999 or book one via the bosch appliances website (customer service drop down)
Apr 02, 2013 | Bosch Washing Machines
What does E-13 mean?
Low water pressure.
If this is the error message your washing machine is sending, it may be caused by inadequate water flow. There might be something trapped in the water hose such as sediments or lime deposits. If you are using tap water, this is a common problem.
Remove any sediments or dirt obstructing the flow of water in the hose. Pull the sensor that is located n the inlet valve and check inside to see if anything is trapped.
Dec 07, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch E13 error on washer - shows e-13 and door will not open.
Hello & Welcome to FixYa
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Classixx 1400 Express: stopped midway through wash cycle, making a high-pitched beeping noise. Water and clothes are trapped in the machine. I have tried setting it to drain and spin - just makes a...
if there is still water in drum the door wont open try tilting the machine back so the water is not touching the door and wait for a click that normly works
Mar 28, 2011 | Bosch Washing Machines
My Bosch front loading washer is flashing E:13 and won't open
Hi, i had an E-13 error code on my Bosch 500 series washer. The drain pump impeller was plugged. Access the drain impeller at the bottom front right corner. Just put a pen in the hole and turn the cover. Then you need to manually drain the washer. I used a shop vac by just turning the cap until it started to leak and vacuum the water as it comes out, this takes quite a while. When you get it drained you can take the cap completely off. When I did I found a wipe in the impeller. I took it out and put it back together and the washer worked just as before.
Take care
Jun 13, 2010 | Bosch Nexxt 500 Plus WFMC5301UC
Hello! My Bosch Nexxt series 300 washing machine is showing a E: 13 error and won't open. I have tried unplugging it but that doesn't seem to help.
e 13 is a door lock error if you are lucky you may have a manual release check where filter is for a red pull release this mechanically activates the door to retrieve trapped washing,if not lock will need replacing engineer visit unfortunately.
Aug 05, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Can't get locked door open
For the door locking problem, on several of the Bosch washers, there is a round plate at the front bottom with a hole in it. One can place a thin phillips screw driver or some thing that goes in and turn the plate while pressing the plastic latch behind the hole to open the plate.
There is a mecahnical door lock release mechanism you can see or reach inside. Open the washer door while pulling on that. You can atleast get to your clothes inside.
There is a filter/drain mechanism inside this area. The manual and the postings here suggest a few more things you can do further to remove junk/blockages in this, but that is a messy job.
Feb 06, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Vision 300 Series WFVC3300UC Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
