Question about Zoom Wireless-G 4410 (44100000) 802.11g/b
Computer restarts every time
My computer is restarting every time i switch on. I tried to safemode it is not enter in to the home page. It is again restarting. I put windows CD to re install, but repair option also not working. I want only C drive to format and re install operating system. but it does not allows. In other drives my files are there. So, I want only c drive format. but it not working. how to solve the problem. Give me your valuable suggestions.
  • Adam Mcbride May 11, 2010
    Are you getting a blue screen error before it restarts?
    Problem Solver:
  • 5 Answers
You better check your restart switch... that might be pressed on....if so unscrew your computer and the cable that passes thorugh the reset button take that out...( you can unplugged) ... for that, you can follow the diagram inside. of the computer...
perhaps it may help your problem....
and to format c drive. you have to install operating system cd and can follow the instructions if your computer's reset button works first...
Posted on Apr 23, 2009
My computer screen turns blue and restarts window vista
Hi jjlishus,
I see you mentioned that you are having issues with you computer going into a blue screen then it restarts.
You can try to boot into safe mode to see if Windows Vista will Load without having the bluescreen and if it will not shut down or restart, from Safe Mode, try and do a system restore to a data where the problem has not happened yet.
From there-on see if the issue will still happen or no
Getting into Safemode:
restart PC keep on tapping F8 on your Keyboard this will prompt you options, Look for Safemode then press enter this should bring up the safemode screen.
If during the loading of safemode and still happens are any error show up or it goes to a blue screen, you can try going into safemode with command prompt.
to get to safemode in command prompt just do the same as ging into safemode and select safemode in command prompt.
once in the command prompt
Type CHKDSK , then press enter it should check the system for 5 mins or so depending on your PC/Laptops speed.
if still the issue is the same reformatting or restoring your windows back to defaults may fix the issue.
I hope that this will help,
mvincentc
Jun 07, 2012 | Acer Brand 14.1 WXGA Matte Laptop...
My computer says configure updates and then it automatically turns off
This will be a long process of troubleshooting and may end up of restoring your computer to a factory settings. You can try the steps below:
First is boot up to advance boot options, to do this follow the steps below: -Turn off your computer -After pressing the turn on button start tapping F8 key until you see the Advance Boot Option. -Try choosing Last Known Good Configuration if it fail try Safemode, Safemode with networking or safemode with command prompt, if one is successful use system restore to restore your computer to an earlier date but if it fails you'll need to use your Operating System Disc to use the repair option.
Here's how to access system restore incase you're able to access Last Known Good Configuration, Safemode, Safemode with networking or safemode with command prompt: Windows XP: Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
Windows 7 and Windows Vista: Click Start, point to Programs, point to Accessories, point to System Tools, and then click System Restore select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
If you're on safemode with command prompt: At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER, System Restore window will pop-up then select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
If all the steps above fails you need to use the recover disc or the operating system disc to do a repair on your computer. Revert back in case you need steps for using start-up repair.
Note: If the steps above and start-up repair fail there's no other option but to restore your computer to factory settings.
Apr 21, 2011 | Acer Aspire AX1700-U3793A PC Desktop
Cannot delete scenes from computer after being downloaded from camcorder
You may run the pc on safemode to remove the video file.
Restart the pc and tap on F8 continuously until advance boot options appear.
Just select safemode and press and on enter
try to delete the video again.
Apr 18, 2011 | Computers & Internet
Acer Aspire One netbook freezes upon start up and will not shut down...still froze! Just got for Christmas this year. Only 3 months old.
Hi jenksjodikay,
If your system freezes up during boot up, a file in the OS might have been accidentally deleted or corrupted. You could also diagnose what happened on your system by checking if you have installed something new that caused the issue. There are several ways to resolve this, either you try to do a windows system restore or you reformat the system. But before reformatting your system you need to get all your data off the computer or else you will lose everything.
I recommend trying to do a system restore, it would help you to sort the problem out. Please follow the steps below:
1. Turn the computer on or just restart the computer.
2. After switching on the computer, start tapping the F8 key. "Windows Advanced Boot Options Menu" will appears. If you're not able to do so try restarting the computer and try again.
3. Now select the "Safemode Option".
4. Ensure that you press the enter button to select it. Computer will then begin to start in safemode.
5. Now click [Start] point to [All programs] go to [Accessories Folder] then [System tools] and click "System Restore".
6. On the "Welcome system restore" page, click the "Restore my computer to an earlier time" option then click next.
7. On the "Select a Restore Point page", click the most recent system restore point in the On this list, click a restore point list, and then click Next.
--> A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
8. On the Confirm Restore Point Selection page, click Next and it will restarts the computer.
Hope it helps,
Thank you for using FixYa.
Feb 14, 2011 | Acer Aspire One PC Notebook
Hello, I have an Acer Aspire 5532 and the battery died while it was unplugged. Usually I just plug it up and press the power button and it will ask if I want to load Windows (normally, safe mode, etc.). I...
hi,
Try the below steps:
Shutdown the computer and Restart it, as soon as it restarts keep on tapping F8 key, now select, "Last Good Known Configuration" and hit "Enter" key. It should take care of the issue. If not, then boot the computer to "Safemode", to do so, restart the computer and as soon as it restarts keep on tapping F8 key, now select "Safemode" from the Advance boot menu. If it is booting to Safemode, then perfomr a system restore to previous date. If nothing happens, then you have to perfomr a full system restore.
Jul 30, 2010 | Acer Computers & Internet
Gigaset 567 wireless router. unable to connect from desk top to laptop
try to disable the antivirus software and try to connect again, if this doesnt work try to go to safe mode w/ networking
to go to safemode w/ networking you can try this options:
when using windows XP, Vista and Windows 7. try to restart the computer as soon as the computer turns on immediately strike F8 key continuously, in advance menu option or advance boot option use the arrow key to highlight safemode w/ netwokring and hit enter ( if you see you operating system just hit enter again )
or try this one:
for windows XP,
click start
click run, type in msconfig
in msconfig click the tab for Boot.ini click safeboot at the bottom and choose network, hit enter
click apply and ok
for windows vista and windows 7
click start button or the pearl
type in msconfig in the start search and hit enter
click the Boot tab
click the safeboot and choose networking
click apply and ok
i hope this helps
Pls rate my resolution thanks!!
Mar 04, 2010 | Siemens Computers & Internet
I restarted my Hp 510 laptop and it completely got
well, you can try pressing CTRL+ALT+DEL while on the log on screen if you're using xp... are you?
Nov 14, 2009 | HP 510 Notebook
The system is getting restart continously,while booting
  • 1. Got to your Start menu and select “Run” option.
  • 2. Type in msconfig command and click OK. The System Configuration Utility program will then open.
  • 3. Select the BOOT.INI tab located at the top of the System Configuration Utility window.
  • 4. UNCheck the box labeled /SAFEBOOT and click OK.
  • 5. When asked if you prefer to restart the PC immediately, or Exit Without Restart, choose to restart the computer manually.
  • 6. Your computer will automatically boot into Windows XP Normal Mode when you will restart it.
Dec 16, 2008 | Microsoft Windows XP Home Edition
My computer keeps restarting
do you see an error message at some point?
describe in which part specifically your computer restart?
what were you doing last before the computer started acting up on you?
it may be a driver problem:
have you tried to restart in safe mode?.. after the post sequence press f8 and start the computer in safemode. there are other options you may want to try from the advance startup menu that comes up when pressing f8. if you are able to start the computer in safemode your problem most likely is with a driver.
did you install new hardware?
try uninstalling the new hardware and restart the computer to see if that solves the problem
you may have a problem with some configuration files or booting files...
try to restart your computer with a windows 98 boot disk. first download the disk from http://www.bootdisk.com/ and make a floppy disk as directed. then get into the cmos/bios of your computer and make sure your first booting device is your floppy drive, then put your newly made win 98 boot disk in the floppy drive and restart your computer. at the prompt type c: then enter then type win
Sep 24, 2008 | Dell OptiPlex GX260 PC Desktop
Zoom Wireless-G 4410 (44100000) 802.11g/b Logo
124 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
