Question about Tools & Hardware - Others
Cant get stapler open, rexel long arm stapler
2 Suggested Answers
tiffany_shac
SOURCE: how do I open up a rexel stapler?
There's a plastic button on the back of the Rexel stapler that says "press."
Posted on Nov 17, 2012
Rapesco 813-D stapler. What staples will fit?
try rexel for a replacement, they might do the job.
Aug 09, 2015 | Staples Tools & Hardware - Others
Rexel stapler
Sadly, the solution to this problem is very simply, and stated on the instructions for the stapler, which I ignored myself until I had bought my third one and continued to have the jamming problem. The solution is you HAVE to use the Optima staples they sell. Look for them in the silver metal box, and they are labeled Optima. Once I did that, all three of the staplers worked without a hitch, and I love them. Good luck!
Sep 30, 2013 | Swingline 48210 Optima ® 70 Electric...
How to load staples into rexel easy touch stapler
If you imagine that the end that the staples come out of is the front, then the back is where you load the staples. Your picture shows a small black bit at the very back of the stapler. You have to remove this, usually by pushing it in and lifting it up. Once loosened, it should pull out from the back of the stapler. You should then be able to reload. Finishing is the reverse process.
Nov 05, 2012 | Tools & Hardware - Others
Has anyone found substitute rexel titan No 37 staples for the rexel titan tacker gun yet. The No 88 staples although they fit the gun do not fire as they are not fine enough .The original No37 ones are...
Rapesco Part number is: S14082M3. I've used these without problem
apparently Rapesco has now changed to Tacwise and they are now sold as
Tacwise 0346 (Type 140)
Oct 09, 2012 | Office Equipment & Supplies
My rexel stapler does not work, any help[
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Sep 11, 2012 | Office Equipment & Supplies
How do I open up a rexel stapler?
May 04, 2012 | Tools & Hardware - Others
I have a rexel odyssey heavy duty stapler but the spring has popped out, how and where do I attach it back on?
Rexel Odyssey heavy duty stapler: The pring that pushes the staples into position can come losse if the stapler iss dropped. It's difficult to work out how to replace it! However, there are only two "lugs" that will take the circular ends of the spring. One obviously fits to the sliding staple retainer. The other to the back end of the pressed-metal inner body. However, to work, the spring must be threaded from this point along the pressed metal parallel-sided inner body back through a slot and over a rounded bent piece (shiny from prvious friction) and back down to the sliding staple retainer. It's trickey to do, but that's where it has to go in order to provide forward tension when the Stapler is closed.
Aug 02, 2011 | Office Equipment & Supplies
I just received the Swingline SmartTouch Stapler, but the problem is ... I CAN'T FIGURE OUT HOW TO OPEN IT TO LOAD STAPLES. It's getting rather frustrating. What's the trick?
I can solve it!!!!!!!!! Remove the clear tape at the front of the stapler...the tape you cannot see, and push from the back of the stapler! Please note on the bottom of the box......it reminds you that this stapler does not come with paper or staples!!!
Mar 30, 2011 | Office Equipment & Supplies
Hi Guys Rexel Cosmos 210 Stapler (Staple Gun - Mk II) I have a Rexel Cosmos 210 Stapler that has a broken white plastic bit. I have had it and used it at work for about 25 years. How can I get a...
I have one equally old and my plastic bit broke off many years ago.
I just get used to using it without.
It sticks but it's such a good stapler I forgive it.
Jun 12, 2010 | ACCO Brands Office Equipment & Supplies
Old Rexel 1250 - falsely detecting safety cover is open
You'll have to unplug the machine, then remove the screws front (inside door or cabinet) and rear to remove the top cover. Insure that the safety cover arm which contacts the microswitch is not broken or the microswitch is out of adjustment.
Oct 24, 2008 | Office Equipment & Supplies
Tools & Hardware - Others Logo
71 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
