Question about Intel DG31PR Motherboard
Intel DG31PR Booting Problem.
Intel DG31PR with Dual core E2200 does not show display in the monitor while booting. The buzzer beeps when Ram or CMOS jumper removed, but does not beep when CMOS battery removed. Hope someone could help me!
  • 5 more comments
  • T Raja Prabhu Apr 23, 2009
    The machine does not beep if the ram is in.
    Tried solution No.1 but unfortunately does not show any signs on the screen.
    It is a on-board graphics, and I have not yet installed the PCI Express card. Thanks for your support
  • T Raja Prabhu Apr 24, 2009
    Not sucessful even with PCI Express card, hence I have sent the Motherboard to the manufacturer for rectification. Shall keep posted of the outcome. thanks
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Does the machine beep when the ram is in and if it does count how many there are and if they are long or short.
    Post back please.
  • Anonymous Mar 14, 2014
    intel dg31pr motherbord has no display after booting
  • Intel Master
  • 4,806 Answers
Try resetting the bios by removing the power cord from the back of the machine and removing the battery for an hour periodically hitting the on/off button to dispel and residual power, then try again.
post back please.
Good luck and thanks for using FixYa!!
Posted on Apr 23, 2009
  • Lee Hodgson
    Lee Hodgson Apr 23, 2009
    are the graphics on-board or are you using a card?
  • Lee Hodgson
    install the PCI Express card and try it on that.
    Good luck
I have Intel Dg31PR motherboard.. When i booting it display is not working. no beep sounds also.. how may i fix this problem.. please help me...
when i instlln dg31 pr by intel motherboard cd ..all driver istalled but the audio driver failed to install\r\n
what should i do
Feb 11, 2011 | Intel DG31PR Motherboard
Hi, I have an Intel DG31PR mobo with nVidia 460GTX Intel Core 2 Duo 3GB RAM DDR2 Was working fine. Changed casing today and 1. no display shown 2. mobo gives 4 beeps and reboots, goes back to...
Points to a mobo problem.
However, it could be a short, caused by an unseen standoff pillar making contact with the board.
I would first of all, remove the board, place it on an A.S surface and connect it to a monitor, with 1 stick of ram, No hard drive and no CD rom attached. Use a makeshift power switch to trigger the power on the Fpanel header, or carefully touch the Power pins with a screwdriver to boot it.
If that fails to work, check the board for burns, blowing capacitors and damage, especially underneath
If it does work, replace each component in turn, examine the case to see you are not placing the board on a standoff pillar that will not be taking a screw
Jan 07, 2011 | Intel DG31PR Motherboard
I have 9600 gt Graphics Card on Intel DG31PR with dual core processors & 2 GB Ram. While I starting My PC after 2-3 days then PC started but there will no display at all, hdd led not blink but pw led...
It's the motherboard, the BIOS forgets that there are components attached to the board and can't detect them.
Time for a new motherboard, this one is unfixable and it you wait too long it will fail while you use it with who know what consequences.
Oct 04, 2010 | Intel DG31PR Motherboard
My PC is not booting!!
first try to boot with new ram or try your ram in other cpu to confirm that its due to ram problem or something else......then try to replace your cmos battery or chk it with multimeter whether its working or not then try to change SMPS with new one............
Sep 28, 2009 | Computers & Internet
E2200 Duo Core refusing to boot with P965T-A motherboard
Have you tried cleaning the RAM? Here's how it's done, remove the RAM from the DIMM slot of the motherboard and rub the pins with pencil eraser as shown in the image below:b239e53.jpg
then install again to the motherboard. Same goes with the graphics card (if you have one installed). if problems persist, replace the RAM..
Sep 25, 2009 | EliteGroup P965T-A Motherboard
I have Intel DG31PR series motherboard with 2GB
The number of the beeps is a specific post
error code and should help diagnose. e.g.:
my computer has 3 beeps to indicate RAM
failure. Note the beeps and find in your manual
or from Intel support.
Here's some help to get started:
Beep Codes
Intel Support
Jul 12, 2009 | Intel DG31PR Motherboard
No display
Beep codes are usualy heard when there is a problem with either your display card or your RAM.
Your problem could possibly be a faulty CPU.
Does your CPU work in another board, or can you try another CPU in your board?
Regards,
Graemevm
Apr 23, 2009 | Intel Motherboard, 945GC, Core 2 Duo,...
Intel Dual Core 2.0 GHz Sytem hangs after boot
During your boot screen press the F8 key to boot into safe mode. If that gets you to the desktop run virus/spyware scans. Reply with any results.
Jan 12, 2009 | Bravo Intel Dual Core E2180-2.0GHz 2GB RAM...
No beeps, No video but fans and lights come on...
Its the DG31PR bios!
Put a non 45nm CPU on it, update the bios to the latest one , put back your 45nm processor and all should work just fine....this board is awesome.
Cheers!
Apr 18, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
630 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
