Question about Pride Mobility Products Jazzy 1170 XL Plus
Jazzy stopped one day. Plugged in charger and it will still not move. Replaced batteries and it will move a couple feet then stop.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Shouldnt even move with charger plugged in sounds like a controller problem or joystick have a tech fro dealer check the error log they can tell u what is wrong from that
Posted on Jan 20, 2014
4 Suggested Answers
  • 692 Answers
SOURCE: I have a Jazzy 14 xl when plugged in the charger
same thing as the other fellows problem Batteries!! the charger is supplying the power to light up the joystick but when not plugged in the batteries are so low they can't turn your chair on. Replace both batteries good luck Hope this helps
Posted on Oct 31, 2010
  • 347 Answers
SOURCE: jazzy 600 plugged into outlet.
Hello.Visit -www.alldatasheet.com its free.Download a troubleshooter as a PDF File of your product.Save + print if you choose to your Adobe Reader.Merry Xmas,any problem,please ask again Colin.
Posted on Dec 16, 2010
  • 692 Answers
SOURCE: I have a Jazzy 1113
huntin you might not get a reading at the plug to the batteries because if its not connected to a load the charger might operate until it senses a load. a better way to check would be to plug the charger into the outlet and take your meter set it to 200 volts dc and plug it into the two outter holes of the chager port located under the front of the joystick. you should get 27-30 volts dc with the charger plugged in. when you unplug the charger you will be reading the battery voltage. After charging overnite you should be reading 26-30 volts dc if you aren't getting that voltage replace the batteries Hope this helps
Posted on Mar 24, 2011
Testimonial: "Thks for the info.It was real helpful in finding the problem with my Jazzy 1113 chair ."
HOW DO I GET THIS JAZZY 1120/2000 TO MOVE FORWARD? AT THE PRESENT TIME IT APPEARS TO BE IN A LOCK POSITION. WHEN I PUSH THE JOYSTICK FORWARD IT WILL GO FORWARD AND STOP THE SAME FOR THE REVERSE IN A LOCKED...
Good evening.Download this Adobe Acrobat Document:- troubleshooting_2007 SHOPRIDER.pdf
In there you will be delighted what you find,its 36 pages long.Pages 1 to 5 batteries and chargers 6 to 18 on scooters & 19 to 36 on wheelchairs.Any problems ask again.Have a nice day.Colin.
Nov 15, 2010 | Pride Mobility Products Used Jazzy...
Jazzy 1121 power chair won't charge when plug in to charge chair can move when you use joystick
you have either bad batteries or a bad charger or the charger might have come unplugged at the controller or power module. When you have the charger plugged in and you turn on the joystick the lights on the joystick should ripple to indicate the charger is plugged in. If you don't see this ripple then either the charger is bad or disconnected. Trace the charger cable from the rear of the chair (you have to remove the seat and shroud to do this) to the front module and make sure that the cable is plugged in. Hope this helps
Oct 22, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Runs about 60 feet and quits. no click from the solenoid. wait a couple days and it will repeat same problem. It is an old model but was never used. I bought it from teacher who prefers her scooter
Unfortunatly, it sounds like your batteries will not take a full charge need to be replaced.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. The charger will indicate the batteries are full, but instead of being full of pwer, they are full of crud. Since you are the second owner, the repairs are up to you. You can probably find compatible replacement batteries from Interstate Batteries, Batteries Plus or Battery Warehouse. Good luck!
Oct 22, 2010 | Pride Jazzy 1650 Heavy Duty Power...
I work at a homeless clinic. We had a Jazzy 1170 donated and we charged the battery for about 7 hours. When we tried it out it moved very slowly. Nothing was registering on the amp meter on the back. ...
Yes you probably need new batteries. If you have access to a digital voltmeter set it to 200 volts DC and plug the leads into the charger port located under the front of the joystick. Plug it into the 2 outter holes. Without the charger plugged in you are reading the battery voltage it should read 24- 27 volts. Now plug in the on-board charger and the voltage should go up to 27-30 volts. If you don't get at least 24 volts w/o the charger plugged in then the batteries are bad. If you don't read 27-30 volts with the charger plugged in then the charger is bad and unfortunately both might need to be replaced. Hope this helps
Sep 14, 2010 | Pride Mobility Products Jazzy 1170 XL Plus
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Pride victory and pride jazzy will not charge the batteries and when plugged in. The inhibit function seems to not be working either.
Bad charger port on joystick only fix is to replace joystick or if it has a seperate charger port underneath the jostick that has to be replaced
Aug 07, 2010 | Pride Jazzy 1103 Ultra Standard Power...
How do you reset the dc charger on a jazzy 14xl the batteries have been replaced? thanks
Chargers generally do not need to be reset. But in some cases if you may want it to start a Bulk charge.
If the charger is plugged in to the mains and ON, Then switch OFF and leave unplugged for 2 - 5mins.
Meanwhile Switch Jazzy ON and try and put some load on the batteries by taking it for a short but power consuming trip usually by going up hill.
Then plug charger in and switch on and the charger should initiate a full charge sequence.
Aug 06, 2009 | Pride Jazzy 1103 Ultra Standard Power...
Pride Mobility Products Jazzy 1170 XL Plus Logo
85 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
