Question about Philips 60PL9200D Projection Televisions
65 error code
I have a Philips 60pl9200d/37 that will not turn on. When it is plugged in; the lamp comes on for about 3 or 4 seconds then goes out. The fans are on for about 90 seconds and after hearing a relay click; the fans turn off and the on/off button starts to cycle 6 slow flashes follow by 5 slow flashes. I have replaced the lamp and the color is operating. What else could be causing this problem??
Ecollier2012
  • 3459 Answers
SOURCE: Projection Lamp for Philips 60PL9200D/37 TV
More than likely the problem is the CRT fluid and not the tube. Do a few google or fixya searches on CRT fluid and to get an idea of what it looks like when it gets cloudy.
Posted on Nov 18, 2008
  • 35 Answers
SOURCE: my DLP tv will not turn on the power button flashs
have you changed the lamp? J.D.W.
Posted on Jun 18, 2009
eagle338
  • 4889 Answers
SOURCE: philips tv. model.# 60pl9200d/37. picture
Clear case of lamp failure. When was the last time you have replaced it?
Posted on Dec 27, 2010
  • 8457 Answers
SOURCE: i have a philips tv model number is 60PL9200D/37.
U hear alots of clinking too,when tv power on and the projection lamp tried to come on?Yes,tv have a problems with it board call the Ballast board also.This Ballast board only job is to help ignite the tv projection lamp.
Posted on Feb 03, 2011
taran_2005
  • 10515 Answers
SOURCE: Philips 60PL9200D/37 - dark picture for two weeks
There is a very good chance that we have a bad lamp here again. Which is about the best case for you.
I think the first thing we should do here is take it out and inspect it. We might find that it is shattered and know without a doubt that it needs to be replaced.
Also if you don't know about the lamps in these sets here is some information: These lamps are a "consumer replaceable item" meaning they are made for you to change. This is similar to changing a light bulb in a lamp but allot more expensive and a little more difficult. These lamps last on average anywhere from 1 to 3 years before they need to be changed. They also burn out based upon the number of hours the tv is on and the number of times the tv is turned on in its life. The more you watch the tv the faster the lamp will burn out, and the more you turn the tv on and off the faster it will burn out. There is really no way to prolong the life of a lamp other than not watch the tv, so most people don't worry about it to much and just expect for this to happen ever couple of years.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 03, 2011
I bought a lamp for my Misubishi 1080p and its not coming on flashing yellow
If not same issue as before lamp replaced double check that it is in correctly and door is closed--this set should also have a self check:
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
This is for another model so codes may be different but see what code you get.
Nov 08, 2012 | Mitsubishi WD-Y657 65" HDTV
Which fan do I need to buy to replace in my 60pl9200d/37
Lamp fans fail most often from the heat---good luck getting one with no idea of which you want---Philips not known for being real helpful to consumers.
What is set doing or not?
Nov 05, 2012 | Philips 60PL9200D Projection Televisions
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
I have a philips tv model number is 60PL9200D/37. when i turn on my tv the blue power light flashes and the lights and fans cut on but not the actual screen. after a few seconds of blinking the lights and...
Feb 03, 2011 | Philips 60PL9200D Projection Televisions
Philips 60pl9200D/37. Two Red lights on power button.
If the power button is displaying the bulb fault indicator AND overheat indicator lights at the same time, it indicates a faulty cooling fan. The television is smart enough to detect when either of the two cooling fans in the chassis have failed, or aren't spinning fast enough. To prevent overheating and damage, the set will not turn on if a fan is faulty. You'll need a replacement fan.
Jun 20, 2010 | Philips 60PL9200D Projection Televisions
Philips 60PL9200D/37 has no display with new light engine/power supplt/lamp assembly/ and SSB
Did you change the lamp yourself or was it serviced,and when it was changed was the ballist(s) messed with? It may be the ballast that caused the problem to begin with.
May 09, 2009 | Philips 60PL9200D Projection Televisions
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
Nov 12, 2008 | Philips 60PP9202 60" Rear Projection...
Mits diamond vision 65
Dec 26, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Philips 60PL9200D Projection Televisions Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
